Master Cylinder leak question
My master cylinder for the front brake on my SuperGlide is leaking a little bit. I tightened the two screws real tight and now it's worse. I ordered a new cover (paint all peeled off the old one) and new gasket, my question is "how tight do you tighten the screws to get a good seal?" I can't see anyway to torque it to a spec with a screwdriver, so how tight? Hand tight? Really tight? lightly tight? Thanks!
Received 4,770 Likes
Here's another guy that just experienced the same problem. In 36 years of owning these animals, albeit only 2 with disc brakes, I never had the screws come lose, until now. Will always check them from now on as it could have been a disaster if that DOT 5 started splattering all over the place. Good advice on the "just enough to see the gasket begin to compress".
The service manual says 6-8 in/lb of torque on the master cylinder cover. They do make a screwdriver style torque wrench that will go down to 5 in/lb. We have them at work made by Snap-On. Mine was leaking until I loosened it up some. I still need to replace the gasket but haven't since it stopped leaking. I had the same issue...I tightened it up more and it leaked worse.
