Ohlins shocks
Ohlins shocks
I haven't had a chance to contribute to the Forum in a while, but I rode down to Deals Gap and rode 129 last week. I've ridden the Tail of the Dragon before, but this was the first time with the Ohlins shocks(36PRCLB) which I bought from Howard Messner at a good price. The shocks are 340 mm eye to eye or 13.4"- 1.4" longer than the stock StreetBob shocks. I put dual Brembo brakes and Racetech cartridge emulators on the front, Metzler 880's on front/back before installing the Ohlins. The shocks are fully adjustable- compression, rebound, preload. Front end rake/trail was stock specs before raising the shocks, so the raised shock length gives a little quicker response on the corners, but not so much as to change stability at speed. Trail is still sufficient to ensure high speed stability. Here's what I experienced on the Dragon:
The bike was MUCH quicker in the corners on Rt 129. On the tight turns I easily maxed out the lean angle scraping pegs(even with the increased shock length) without losing any stability in the turns. It was amazing what a difference the Ohlins shocks made. The bike changed from right to left lean turns in the tight S turns like a panther. No oversteer, understeer; significantly increased speed from my last trials. I didn't have a stop watch on the performance, but my "feel" for the road was much improved over the Progressive 440's I had on before.
I took my time coming home- secondary roads through Kentucky and Tennessee. Beautiful ride on the Cherohalla Skyway, etc. When I got to Indiana and Ill. I hit the interstates. At one point I was riding at about 65 on concrete pavement, and the ride felt rough. I reached down and decreased the compression damping(not the best way to make changes on your suspension, but I wanted to experiment) and noticed a very significant improvement in the ride. The point I took away from this little experiment is that a fully adjustable suspension can make a huge difference, not only on making a bike quicker on the track but also remarkably more comfortable under different street conditions.
Boy, do I recommend improving the suspension with a good set of shocks! The Ohlins are expensive, but they have made a huge difference. BTW, so did the dual brakes. The rear brake was smokin' hot, but the front brakes did their job- no fade on the 300+ turns of Rt. 129! No fade! Jay
Racetech Cartridge Fork Emulators
You did'nt have much to say about the Racetech emulators. Iam planning on putting them on my 08 Dyna when I put my chrome fork legs on. Did you have to play with the adjustments to get the front end working properly ? What weight oil did you use. I have the progressive front springs in my forks now and was wondering if they will work ok with the racetech parts ? I was also thinking about the Ohlins. Can they be shortened any I have 13.25" shocks on my bike now and Iam not sure I want to go any longer then that. Do you know where the cheapest place is to purchase the Ohlins ?
Thanks >>>> Inthered
