Swing Arm Bag
Old 06-08-2009 | 07:07 AM
thezoeman's Avatar
thezoeman
Looks good man, I like the look a lot.
Old 06-08-2009 | 06:55 PM
columbia whaler's Avatar
columbia whaler
SH 01 GXDWQG,
I like the electrical cover bag as well..looks good and a very useful location.
Definitely something to consider. Thanks for the link.
Marinepilot81
The bag is about 3 inches away from the belt and I can only move it to about 1 and 1/2 inches away from the belt by pushing the bottom of the bag toward the belt using about 10 lbs of force. I think it would be fine without the belt guard depending on the stiffness of the bag. Results may vary!
Idea: You could cut a piece of 90 Deg aluminum angle to screw to the bottom of the swing arm, mounting it using the existing belt guard holes. One side of the 90 would be to the swing arm and the other side of the 90 would be on the outside of the swing arm pointing toward the ground. This would prevent the bag from getting even close to the belt and if it was cut correctly the bag would hide this "preventer".
Old 06-08-2009 | 08:09 PM
SC-Longhair's Avatar
SC-Longhair
Slayerdude, talk about packing light. So, you wear the same clothes day in and day out for five days and don't wash them because you have nothing to change into??? Kinda nasty if you ask me.
Old 06-08-2009 | 08:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Some detachable saddlebags would lower the weight mass and then you wouldn't have a sail for the wind or turbulence to catch. That would also lower the CG on the back wheel. Good luck and have fun on your trip.
Old 06-08-2009 | 11:35 PM
07fxdb's Avatar
07fxdb
don't like the idea of adding weight to wheel. Won't things rattle around in there with the swingarm travelling up and down all the time? There has got to be a better place for that bag...just mho
Old 06-09-2009 | 09:20 AM
SC-Longhair
I had moved my tool bag that is slap full to my swingarm for a while. It didn't rattle and if it did, I couldn't hear it. I moved it back because I just couldn't secure it the way I'd like too. It didn't alter the handling at all in my opinion.
Old 06-09-2009 | 10:43 AM
Stanger's Avatar
Stanger
Whaler,
Great idea, great placement.
Also, great idea of about camera bag on the side!!! May just have to look at that again, closer.
HAve a great trip!!!
Old 06-09-2009 | 11:10 AM
Low E's Avatar
Low E
I like the bag idea, it looks good.
Old 06-09-2009 | 03:04 PM
Shizims's Avatar
Shizims
When I pack for rallys and I am camping I pack very similar, just reversed. I put my T-Bag on the passenger pad, the the sleeping bag rolled in a top roll bag above it. The tent and other stuff goes on the luggage rack and bungees and a net if needed secure that stuff to the rack and also the D rings on the T-bags. The T-bag makes for a nice backrest...
I have the Tahoe T-bag, it's expensive but worth every penny.
Superrust
11-14-2013 01:54 PM
dondee
07-20-2013 02:07 PM
tripwire759
01-12-2010 01:14 PM
Hickey
08-05-2009 11:29 PM
WDR
07-17-2009 02:50 PM
