I've got a squeal, goes away when clutch pulled
Old 06-09-2009, 12:47 PM
El Jinete Fantasma's Avatar
El Jinete Fantasma
El Jinete Fantasma is offline
My bike developed a similar sound three weeks ago. Seems to come from somewhere in the front end, but I can't pinpoint it. I had the neck tightened up last week to get rid of chatter and it's a little better. I mostly hear it when the bike is cold.
Old 06-09-2009, 01:18 PM
dyna07custom's Avatar
dyna07custom
dyna07custom is offline
I dont get how the pulley can be the same size how does the belt look if the spacing is off should chew it up pretty quick
Old 06-09-2009, 02:46 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
Originally Posted by timberwolfz28
ok, after reevaluation, it seems to be coming more from the rear pulley. I've checked belt alignment and tracking, and it's good. Here's my thought:
When I bought the pulley to go with the new wheels, I didn't notice it was 65 tooth. I am wondering if the belt tooth pattern is different for the 65 than it is for the 70. I sprayed a little WD40 on the teeth of the belt and the squeal went away, for about a half mile or so.
With that said... new thoughts? Anyone know for sure if the belts are spacing is different? I won't be able to switch pulleys back until I get back from Louisiana next weekend. But if that's not the problem...
My belt was chirping a bit so I put some baby powder on it (no joke) and it went away. Sometimes the belt will get some kind of sticky on it and the powder changes its friction qualities
Old 06-09-2009, 03:23 PM
rounder's Avatar
rounder
rounder is offline
belt is too tight. Or check where your belt come into contact with the front pulley. if the rear pulley is offset more than stock, the belt may be riding on the out side edge of the front pulley. I would be more apt to say the belt is too tight though.
Old 06-16-2009, 10:19 AM
El Jinete Fantasma
I think the major source of my noise was the side-stand, oddly enough. Hit it with chain lube and it's mostly gone. Strange...
Gunslingertom
EVO
32
05-18-2021 09:30 AM
RedBeard_BassTard
14
10-20-2015 02:47 PM
berndog
Shovelhead
18
07-17-2012 11:56 PM
ShovelSteve
General Topics/Tech Tips
05-19-2010 09:03 AM
wild_ivan242
04-23-2010 10:09 PM
Quick Reply: I've got a squeal, goes away when clutch pulled
