New Slip-On's
New Slip-On's
I know this question has probably been asked about a thousand times but I could really use some help.
I recently installed Rush slip-on's and have been experiencing some popping on decel. Without endng up in the poor house, is there anything I can do to take care of this problem. I've heard about mapping, ECU, saying a prayer and trying vodoo.
Thanks bros
Thanks bros
Thanks bros
Thanks bros
(lets see who figures that one out...)
Make sure you don't have a leak at the joint where you torqued down the clamps. 1 thing you can buy copper muffler paste remove your slips and apply the paste it should help seal the joint. I hope you didn't twist the header pipes removeing the old slips and perhaps break the header pipe seals, but if you haven't changed air filter a leak will be your most likely cause. If you did change air cleaner then you need a re-map not before!
Easiest thing you can do is call fuelmoto today and they will get you through this!
I'm having the same problem. Only notice it when decelerating in gear, and then only when third to second or second to first. Everything is stock except for the slipons.... How much is too much? It's not loud, (not a backfire) but there is definitely a little bit of popping....
Thanks bros
Thanks bros
Remove the 4 bolts that go from muffler to muffler.
Loosen the muffler clamps and remove the stock mufflers.
Put the new mufflers on the same way you took stock off and tighten all hardware. Make sure to look inside the muffler body for day light. If you see daylight then continue to tighten clamp until it’s gone. If you have a torque wrench, tighten to 65 ft/lbs.
Hope this helps, if you have any questions, please drop me another line.
Adam
