Fat Bob Tri Bar LED install ??
Old 05-30-2009, 09:09 PM
wood butcher's Avatar
wood butcher
wood butcher is offline
Originally Posted by luckyB
Like others have said... the install isn't bad. You don't need a jack. You will need to remove the rear fender unless you have extremely tiny hands. Removing the rear feder is easier if you have someone give you a hand so you don't scratch it.
The Tri-Bar taillight should have come stock... looks 100% better.
Agree completely.
Old 05-30-2009, 09:13 PM
wood butcher
Originally Posted by SMOKEin
Great looking dog!!
Nice bike too
Im not sold on the tri-bar, but so few options and such an ugly stocker... I make take off the stocker and tint most of it..
Thanks and thanks. I think the tri-bar light might look good with the stock plastic license plate holder. The stock light might also look better if it didn't stick out so far past the fender.
Old 05-30-2009, 09:35 PM
jb27's Avatar
jb27
jb27 is offline
Thanks for all the advice. I'm still undecided if i want to keep the bobtail fender or go with a chopped fender. I do think the tri bar dresses the tail up.
Anyone try to remove the reflector strip on the tri bar and mount your plate up higher? I've never seen one of theem in person to know if it is even possible.
Old 05-31-2009, 12:49 AM
rexel's Avatar
rexel
rexel is offline
Originally Posted by Nytro B
Here's a pic of the tail light installed. Doesn't take long, you don't need a jack but the fender does have to come off in order to snip the cable ties for the tail light harness (unless you can figure out some other way).
b
It's tight but you can get cut the wire ties and install the tail light without taking off the fender...I had to walk away and come back and finish it later.
Old 05-31-2009, 12:53 AM
rexel's Avatar
rexel
rexel is offline
The reflective strip isn't stuck on, you have to tighten two screw behind it before you put it on...mines still in the box. I didn't move my plate up but I don't see why you couldn't drill two holes and move the plate up.
Old 05-31-2009, 09:24 AM
bastardsuns's Avatar
bastardsuns
bastardsuns is offline
dont stress over the instalation, its a snap, no jack needed, quick tip, dont spend an hour staring at the directions.
Old 05-31-2009, 11:09 AM
jb27's Avatar
jb27
jb27 is offline
Ha. I usually don't break them out until after i'm done and see how many things i screwed up. LOL.
Old 05-31-2009, 06:06 PM
YesterdaysCorn's Avatar
YesterdaysCorn
YesterdaysCorn is offline
Going to order mine tomorrow.......looks sooo much better than stock.
Hey does it come with everything you need or do I need one of those load equalized thingies....
Old 05-31-2009, 09:30 PM
luckyB's Avatar
luckyB
luckyB is offline
It comes with everything you need... no load equalizer needed.
Old 06-01-2009, 04:04 AM
emwolb's Avatar
emwolb
emwolb is offline
they came out first on the screamin eagle springer. and they really looked sweet in that application. bet they really look sharp on the new fatbob. sure is a cool bike the fat bob.
Quick Reply: Fat Bob Tri Bar LED install ??
