Black out Exhaust Shields
Old 05-27-2009, 12:28 AM
rounder's Avatar
rounder
rounder is offline
Pipes look great. what brand paint did you end up using? Good to know the 150 sanding works good.
Old 05-27-2009, 12:40 PM
TheOak's Avatar
TheOak
TheOak is offline
Looks good.
I took my bike out yesterday and the pipes held up well. The spots on my picture are not there and the color is uniform. I will powder coat them when the opportunity allows, but for now its good to go.
Old 05-27-2009, 01:15 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
the do look good man! nice work!
Old 05-27-2009, 03:29 PM
Harley_RN's Avatar
Harley_RN
Harley_RN is offline
Originally Posted by maddghost
I'm guessing you are past the reccomendation stage since it's done ,and it looks like a real nice job! But if I can add a couple of 2 cents....I think you should have shot the pipe under the tommy gun holes, but , and i hope you won't resent this,but IMO I would have left them chrome with that beautiful pewter denim!
Ummm..yah I did notice that the pipe underneath is more noticeable. If I do spray that, I'll probably go with a VHT silver or something to make it stand out. No resentment at all about the chrome choice. I was looking to take a bit of the shiny chrome off to make it more of a chrome/black/pewter blend.
Thanks,
Christian
Old 05-27-2009, 03:30 PM
Harley_RN's Avatar
Harley_RN
It was the Krylon Hi Temp BBQ paint I got a the local Wal-Mart
Christian
Old 05-27-2009, 03:31 PM
Harley_RN's Avatar
Harley_RN
Thanks....it was a cheap and easy afternoon mod.
Christian
Old 05-29-2009, 12:17 AM
emwolb's Avatar
emwolb
emwolb is offline
i hope this information is of value to those who plan on painting something that's chrome. go to the nearest lumber yard, home depot, lowes etc. get a gallon of muriatic acid. and some rubber gloves and safety goggles. remove the parts from the bike first, using a nylon bristle brush, outside where you don't wanna kill any grass, paint the chrome parts with the muriatic acid. it'll remove the chrome, if not all is removed, then do it again. that way you're back to base metal sheet metal(steel) rinse well to kill the acid, dry the parts, and get ta painting. it's how we de chrome hot rodding parts on the fifties cars, and it works on harleys too. heat proof paint like vht etc. and you're set. i hope this helps someone. i use muriatic a lot, as i've got far fewer active brain cells to prove it.
Old 05-29-2009, 12:20 AM
emwolb's Avatar
emwolb
emwolb is offline
please, i didn't mention it, cause the fad is to black out things. don't use the muriatic on aluminum cause it'll eat aluminum, all you'll have left is the steel screws. use a plastic butter tub or plastic dish for your pan as you paint it on the parts also. rinse the area where you used the acid too. it also plays hell with concrete.
Diehappy
12-30-2017 04:28 AM
smitty901
Powdercoat & Paint
07-27-2017 06:04 AM
173rdskysoldier"Ripcord"rider
03-28-2013 10:54 PM
sickboy75
07-24-2012 01:56 PM
badfl97
07-31-2010 07:22 AM
Quick Reply: Black out Exhaust Shields
