Is this the inner primary noise???
I don't hear it when I first start the bike but after I get back from a ride, pop it into neutral and let out the clutch I hear a whirrrrring noise from the left side of the bike. Could be I just cant hear it on the right because of the exhaust. Anyway I was thinking inner primary bearing. Or is this normal?
Thanks in advance!
Thanks in advance!
I'm not a mechanic and can't be sure that it definately IS your IPB. But that's what my bad one sounded like. Problem is... it STILL sounds like that AFTER the replacement. Oh, the bearing that was removed was definately fried.
Sorry if I confused you. I'm confused too!
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Easiest way to tell: With the bike idling in Neutral, pull in the clutch and kick it into gear for a moment. Shift back into Neutral and keep holding the clutch in. Roll on another few hundred RPM, then release the clutch lever. If you hear the whirring noise spool up as the clutch lever is released, it's coming from your IPB. My 2nd failure was kinda subtle; could hear it, but rolling up the RPM's made it easier to hear. Even the HD Tech. thought it sounded "normal". When I asked them to open it up, there was metal transfer between bearing & race, thermal discoloration of the bearing, and metal in the oil. The first time, you could hear the whirring noise from across the street.
I can't tell the year of your Bob from your album pix. If it's an '06, in all likelihood, HD will fix it free. If so, get a copy of the "Amendment To Owner's Manual" letter that HD gave to '06 buyers (saying they'd replace the IPB every 15K miles). Call HD Customer Service in Milwaukee and tell them your IPB is making noise and you'd like it fixed under the terms of the letter. This will establish a "Reference Number" that any dealership can access (gets you, dealer, HD on the same page).
If I can help with any further info, PM me or email my userID @ yahoo. Or search my "Finally - Good News..." thread for copy of the letter and further details. Good luck.
