06 vs 07 EFI differences?
Hi there!
I've found a load based TFI fueler module (instead of the pot based), the Generation III of the Dobeck fueler.
The p.n. is FI-1340ST.
They wrote it's only for 06 Dyna model. I've the '07 one.
But maybe this was the only Dyna available when the unit was built and packaged.
Do you know if there's particular differences on EFI system between '06 and '07 models?
O2 sensors?
Injectors plugs?
O2 sensors?
Injectors plugs?
Hi there!
O2 sensors?
Injectors plugs?
O2 sensors?
Injectors plugs?
There are significant differences between the '06 and '07 models. As pennetta said and JasonL alluded to; the '07 and later models are closed loop systems capable of reading and adjusting the a/f ratio while the '06 is not.
Compatibility with the newer ECM should be verified with the manufacturer.
Hi there!
O2 sensors?
Injectors plugs?
O2 sensors?
Injectors plugs?
