I knew better but I did it anyhow...
Old 05-21-2009, 08:56 PM
YellowHawk's Avatar
YellowHawk
YellowHawk is offline
Default I knew better but I did it anyhow...
I am going tomorrow to Mobile Bay Harley Davidson to get a new tire put on my front wheel. I have some other things to do while I'm in Mobile so I figured I would just take off the front wheel and take it with me. I jack the bike up, remove the brake caliper, loosen the axle bolts and cannot remove the axle. So, I tried putting a block of wood on the threaded end and tried to drive it out...nothing. I decide to spin the nut back on and down flush with the end of the threaded part of the axle and drive it out. I know better but I go ahead...it worked. Now I remove the nut and use a punch the drive it out the rest of the way. But...now the nut won't go back on more than a turn or so before it binds or crossthreads or whatever. I can't really see any thread damage on the nut or axle but apparently it's there. Now I have to see if they can fix that or if I can buy a new nut. Hopefully I didn't screw up the threads on the axle.
Old 05-21-2009, 09:00 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Instead of tapping it out from the threaded end, should have used a screwdriver in the the other end and wriggled it back and forth.
Old 05-21-2009, 09:02 PM
YellowHawk's Avatar
YellowHawk
Yeah, thought about that. I have some at work but I'm off for a four day weekend now and want to ride. I'll come up with one somewhere and hopefully get it fixed.
Old 05-21-2009, 09:04 PM
SC-Longhair
Did you bring the wheel to the dealer for the tire? Bring the axle too. See if they can't rethread it.
Old 05-21-2009, 09:06 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,949 Likes on 1,933 Posts
Just got a new axle last month. It was about $80. Mine had gotten cross threaded somehow too. Seeing as I am the only one who works on the bike it must have been me. D'oh! Still and easy fix.
__________________
Old 05-21-2009, 09:12 PM
PsTaN's Avatar
PsTaN
PsTaN is offline
YellowHAwk ...
Didnt realize we lived that close .... I'm only 80 miles N of Mobile / bout 50 miles E of Waynesboro on Hwy 84. Hope you dont need a new axle.
PsTaN
Old 05-21-2009, 09:29 PM
YellowHawk's Avatar
YellowHawk
PsTaN, what city do you live in? I hope I don't need a new axle either. I'm pretty sure it could be fixed with a die. I'm sure I need a new nut because I flattened the end of it just a bit with the hammer.
Old 05-21-2009, 09:30 PM
YellowHawk's Avatar
YellowHawk
SC-Longhair, I left the axle in the wheel and I am taking it with me. Hopefully they can hook me up. It would really suck not to be able to ride this weekend.
Old 05-21-2009, 09:54 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Been there. I'm getting better at walking away before I do something bad but it doesn't always happen that way.
Old 05-21-2009, 10:20 PM
stevengb's Avatar
stevengb
stevengb is offline
did you loosen the two bolts on the lower leg? Axle should have slid right out if you did?
Quick Reply: I knew better but I did it anyhow...
