I knew better but I did it anyhow...
Old 05-21-2009, 10:26 PM
YellowHawk's Avatar
YellowHawk
YellowHawk is offline
Yeah, I did loosen those two. I followed my manual to the letter. Once I drove it out about a half inch or so it did come right out. That first half inch was tight.
Old 05-21-2009, 10:49 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Anti-sieze is your friend upon re-assembly.
Old 05-22-2009, 06:48 AM
rjmac53's Avatar
rjmac53
rjmac53 is offline
let us know if any damage...
Old 05-22-2009, 07:25 AM
Gutter Man's Avatar
Gutter Man
Gutter Man is offline
Default try a thread file
I have used a thread file many times. They are only about
$10 or $15 and have eight different thread combinations.
Gutter man
Old 05-22-2009, 09:52 AM
YellowHawk's Avatar
YellowHawk
Never thought about a file. I have an appointment at 1:00 and if they can't fix it at the HD then I'll start looking at these other options. I am going to buy a new axle nut and hopefully not have to replace the axle itself.
Old 05-22-2009, 12:05 PM
NoLongerAmember's Avatar
NoLongerAmember
NoLongerAmember is offline
Originally Posted by Gutter Man
Attachment 47234
Attachment 47235
Gutter man
+1 on the thread file. You probably slightly crushed the first couple of threads. You want to try and repair the threads at the end before running a thread chaser down the threads or you may damage the threads even more. You might want to chamfer/grind the end of the axle and use a thread chaser rather than a die if possible. A die will cut and possibly weaken the threads. Get a new nut! Definitely use some anti seize on the axle, but not the threads.
I had a similar problem getting my rear axle out and even though trying every non metallic driver, I could not get it to budge. I finally used a bronze drift to get it out and still collapsed the groove for the retaining ring. I ground the end and used a hack saw blade to open up the groove.
CB
Old 05-22-2009, 03:05 PM
rtcoronet's Avatar
rtcoronet
rtcoronet is offline
6th Gear
you might want to think about geting a plastic hammer for your tool box. they come in sizes from small up to about the size of a 8lb sledge hammer. most tool trucks have or will order you one. don't leave them in directsunlight forever ,they will get all
dried out/deterioated. you can not destroy one by beating on metal with them.
they have something inside to absorb shock also.hard to mess up threads using 1.
Old 05-22-2009, 05:37 PM
moosh's Avatar
moosh
moosh is offline
your not alone..I bought a new nut, chamfered the first thread slightly, and carefully chased the threads with the new nut and plenty of oil......prefect
don't forget lots of anti seize on assembly
Old 05-22-2009, 09:28 PM
YellowHawk's Avatar
YellowHawk
Thanks for all the help...I took the wheel along with the axle with me to Mobile Bay HD. They installed my new tire and fixed the axle with a thread chaser. Good to go now. I will put it back on the bike tomorrow. I bought some anti seize to put on the axle when I reinstall it. I will definately get a plastic hammer. I thought about that when I was trying to remove the axle but I just didn't have one. Now if it will just stop raining so I can ride...I'm off for four days this weekend and it's supposed to rain every day!!!
Old 05-22-2009, 09:41 PM
Bobber S's Avatar
Bobber S
Bobber S is offline
Originally Posted by stevengb
did you loosen the two bolts on the lower leg? Axle should have slid right out if you did?
A+ No way that axle should have been that tight. Should easily come out by tapping at thread end or pulling with screw drive through hole at other end.
Quick Reply: I knew better but I did it anyhow...
