PCIII ?
PCIII ?
If I buy an exhaust that has the o2 bungs and want to run the pc111 instead of the sert, is there a setting to keep and use the o2 sensors and the closed loop? I see all these posts that the pc111 bypasses 02 sensors so you can run other exhausts without the o2 sensor bungs. I want to run the v&H with the pc111 over the sert for tunability purposes, without losing the o2 sensors and closed loop. hope I made sense to someone!!!! Thanks
