I've pretty much decided
that I don't like the looks of the turnsignal relocation kit from Harley.Had it installed last week during the first check up.The turn signal just stands too far from the forks and the fit is not very good, not flush against the fork. It looks a lot better with the visor over the t -sig and h-lite.Just can't decide if it's worth the trouble to change again.What do you all think.
Good Luck
Tom
Good Luck
Tom
RE: I've pretty much decided
I'm not phond of the pinch bolt method either. Waiting on Drag Specialties to come out with a phork tube clamp phor the 49mm tubes. I used a set on my Sporty, and I really like them. Good product. Mounts nice and tight to the tubes, and gives you a choice of where to put them.
I've heard rumors that the 49mm clamps are out, but I haven't been able to phind any yet, so until they are, I'm leaving my turn signals tucked up under the grips.
EDIT: Oops! Drag Specialties makes the clamps, not custom chrome
If you are not happy with the stalks, you could always do what I have done and mount a set of Kuryakyn lights.
The photo shows a set of 50mm ones that I am using with the clear lenses as driving lights. They also come with a set of additional yellow lenses (and red) , so they may be perfect replacements for you.
[IMG]local://upfiles/6578/2356D53B2BDA4AEE9F0F908FB1EDB7A5.jpg[/IMG]
ORIGINAL: phreak
