How I jack my Dyna
Old 04-27-2009 | 11:35 PM
cramil's Avatar
cramil
Default How I jack my Dyna
Some of you have commented on my unorthodox jack set up that is in my sig and featured in my winter mod thread. Sooo I thought I'd share just how I make it work.
First I use my trusty floor jack under the front motor mount cross bar with the bike still on the stand (jiffy or jack depending on your lineage I guess). Then I jack it up as high as it I can and still be stable on the stand (this is actually pretty far BTW).
Then I slide one of my jack stands under the higher side right at the junction of the down tube and the frame under the motor. (these are stands with a pretty deep "U" shape to them). Then I stradle the bike and tilt it up onto that stand and off the floor jack and my son/daughter/wife/friend slides the other stand under the other side in the same spot and I set her down easy into it and check that it is stable and seated in the stands.
This gets the front end off the ground and is stable as a rock.
To lift the rear I can simply grab the struts on either side and lift the back end up and have son/daughter/wife/friend slide another stand under the frame right at the swing arm mounts. (I have done this myself with the floor jack as well)
I know that most of you are skeptical, but I can sit on the bike and wrench on it too with no problem whatsoever. I think it is more stable than a jack as the stands spread out the load and don't roll. Plus the frame is cradled in the front stands and not just sitting flat on a platform where they can slide a bit if shoved.
Old 04-27-2009 | 11:52 PM
benwiggin2's Avatar
benwiggin2
don't show us how you jack anything else, please.
Old 04-27-2009 | 11:57 PM
cramil's Avatar
cramil
Look who's talkin', the guy with a circle jerk of bikes in his sig pic LOL
Old 04-28-2009 | 12:55 AM
benwiggin2's Avatar
benwiggin2
hahahaha effen hilarious!! Good luck with your trees btw.
Old 04-28-2009 | 12:59 AM
OhioSkully's Avatar
OhioSkully
LMAO, you guys aint right and ya whats with that group there i see one's the pivot point another is blowing and a 3 bike circle dam i knew you Cali boys weren't right.
Old 04-28-2009 | 03:58 AM
billyboy890's Avatar
billyboy890
well this is how l do it and its nice and stable
Old 04-28-2009 | 03:59 AM
billyboy890
Old 04-28-2009 | 04:03 AM
billyboy890
and this is what l do when it comes to the winter teardown
Old 04-28-2009 | 04:38 AM
Tat2u's Avatar
Tat2u
heres what i knocked up quick, rubber in the 1/2 pipe bits under the peg mounts, and I throw a floor jack under the back to get whole bike off the deck. man my bike is filthy in this pic....
Old 04-28-2009 | 04:41 AM
maddghost's Avatar
maddghost
check out nightrider.com ,yes the place we get the Xied's, There is a 20$ bike lift anyone could make from local hardware parts!http://www.nightrider.com/biketech/bikelift.htm
Quick Reply: How I jack my Dyna
