AMSoil in trans
BTW this is the first negative feedback on amsoil I've ever heard of.
When i first get on it cold it's fine but after is warms up on the highway it clanks really loud every gear. It wasn't bad until yesturday when it was about 90 degrees here instead of 65-70 and it was BAD. I've been running the gear saver and if i pushed the shifter down just right i wouldn't even get a clunk going into first. And it was silent when shifting up the gears, and if you throttle it right silent going down the gears. As soon as i get paid i'm going back.
Since i bought my bike new i have always changed my own oil, and since my first oil change I have been using Bel Rey Gear Saver. I recently had the trans worked on and the dealer stopped stocking Gear Saver and said they have AMSoil and can put that in instead. This stuff sucks. My trans bangs when shifting so bad, much worse then it did with the factory stuff. It's been warm out here and after 10 minutes of riding it just breaks down or something and bangs every gear up and down. I don't recommend this oil in the trans at all. And yes it is the 80 140 trans lube. I will be draining it out after 300 miles and pouring in some Gear Saver by Bel Rey.
Received 5,298 Likes
I went in to get my primary bearing replaced a second time, and they replaced the cases for the trans and the inner primary and replaced all the bearings in the transmission. They did put in the AMSoil cause it looks like it on the stick and it was listed on the invoice. I can tell it's a Oil issue because it's fine cold and around town a little but once you ride on the highway or it's hot out the trans starts banging which it didn't do with the Gear Savor. My bike did the exact same thing with the original fluid from the factory and as soon as I did my first oil change and put in the Gear Savor it stopped. My wife's 07' Dyna was the same and stopped when i changed the fluid to Gear Savor. So AMSoil in my bike acts the same as the crap from the assembly line. As soon as I change it back i'll let you know if it stops banging.
R Racing had some issues with it a while back:
https://www.hdforums.com/forum/dyna-...-a-lesson.html
Redline now makes a V-twin blend - one for the tranny and one for the primary
http://www.redlineoil.com/products_g...5&categoryID=6
http://www.redlineoil.com/products_g...6&categoryID=6
