Z bars for Bob
Old 05-05-2006, 10:39 AM
hec4sc's Avatar
hec4sc
hec4sc is offline
Default Z bars for Bob
Do you think I can put these z bars on without changing any cables? They're 12' tall, but only 31' wide. I believed the stocks are 10' tall and about 34' wide.[IMG][/IMG] They're available from http://www.lickscycles.com/catalog/p...oducts_id=1193
[IMG]local://upfiles/11762/D4CE4B2CF6C646A8AF36D25C7656F7A1.jpg[/IMG]
Old 05-05-2006, 07:10 PM
jarod7736's Avatar
jarod7736
jarod7736 is offline
Default RE: Z bars for Bob
i'm not positive, but if those are the numbers for both, it sounds like you'll be ok not changing cables. If you're going to run the wires internally, you may have to extend them though.
Old 05-05-2006, 07:30 PM
but Ill try 2 try's Avatar
but Ill try 2 try
but Ill try 2 try is offline
Hurry up and get them installed, you will have a Chica style Bob then.
Old 05-06-2006, 01:25 PM
jarod7736's Avatar
jarod7736
I think Chica does more than add some bars...
Old 05-06-2006, 02:10 PM
but Ill try 2 try
yeah, he smokes cigarettes while adding bars.
Old 05-06-2006, 02:25 PM
16over's Avatar
16over
16over is offline
Z bars have been around alot longer than Chica. Not saying that I don't like his work, because I love it. I just wish he didn't charge $800+ for the "new" Invader wheels that I need for the chopper.
Old 05-06-2006, 02:27 PM
but Ill try 2 try
I know, I know, it's just every time I see one of his bikes they all seem to have those same bars. Must be his industrial/nihilist Japanese heritage, very rigid and defined.
Old 08-11-2006, 06:10 PM
waterman7474's Avatar
waterman7474
waterman7474 is offline
i know this is an old post but to beg your origional question, were you able to do it w/o changing any cables?
if so, what was involved?
Old 08-12-2006, 02:06 PM
hec4sc's Avatar
hec4sc
hec4sc is offline
Nope, everything fit perfect. The wiring is long enough to run it internally also. And the brake line is bent just right to follow the lines of the bars.
Old 08-13-2006, 12:33 AM
TattooedAndScarred's Avatar
TattooedAndScarred
TattooedAndScarred is offline
Pics, Pics, Pics!!!!!!
[IMG]local://upfiles/3645/12B427BE3CB84F29932E01ED77C1BDAD.jpg[/IMG]
Quick Reply: Z bars for Bob
