Mufflers Fell Off My Bike
I'm wondering if this has happened to anyone else. I was driving down the road (50-60 mph) two days ago and the stock mufflers on my 2009 Street Bob simply fell off the motorcycle. I haven't removed them since I bought the bike last september. When I retrieved the mufflers and put them back on I found that the only thing holding them onto the bike is the clamps that attaches them to the header pipes. When I loosened the two clamps I found they were both still very tight. They have a bracket that holds the two together but the bracket does not attach to the bike. A poor design if you ask me because the header pipes are bracketed to the engine/trans and the mufflers are the heavier part of the system and they are held on just by the tension created by the clamps. Anyone ever have a similar experience.
On the fatbob there is a small bracket that holds the slips together and a large black on near the beginning of the slip-ons with three tread bolts /with ordinary hex bolts . They got loose once and I could hear the rattling which went away after the pipes warmed up. So the HD tec just tightened them and told me it was actually a weak poit (obvious) but that he was seeing 4 or 5 per summer come in. So I let that go and don't you know a few weeks later I'm riding and I hear PINNNGGGG. Well two of the threads had just sheared off and the third was loose. They drilled out all three and re-threaded the holes and replaced with actual bolts....so far so good!
