Vibration through handlebars fixed , on 08 DYNA
#51
Well, just bought a spankin' new '09 Screamin' Eagle Fat Bob and it is unrideable at 2800 rpm when going down the road. Shimmed the front mount with (1) washer per and it helped a little, took it to the stealer and they dinked around for 8 HOURS "aligning" my mounts instead of replacing the front one like they should. Now they tell me to bring it in again to swap front mounts, I guess they have had a lot of issues with the front mount being bad, even though it may look fine. Not what I expected for my 1st Harley with less than 300 miles on it... - RK.
#52
To make sure I understand the logic here...The tighter the engine is to the frame, the less vibration you'll get. As such, you unbolt the engine mounts to see if there is any play. If there is a void, you fill the void and retighten? Sounds simple, yet makes no sense. Please explain how that helps reduce vibration.
#53
It is just like a shock aborber. If you have to compress a shock absorber to fit bwtween 2 mounting holes, you no longer have the full range of the shock available.
I had to shim my front mount on my 2006 FXDCI. After doing so, the vibes were mostly gone and now I can see out of my mirrors.
#54
When the motor mount is flush to the frame with no screws, it reduces vibration because you have the full range of the rubber isolator to absorb the vibes. When you have to use screws to draw the motor mount to the frame, the rubber isolator does not have it's full range available to absorb the vibes.
Yep. Good explanation.
I just did this a few weeks ago.
Used a jack to support the engine. Removed both bolts. Shimmed with 3 grade 8 washers, and then used 1/4" longer grade 8 bolts.
The results are dramatic. No vibes at all in the bar. Minimal in the pegs. And at idle, the front end isn't bouncing all over the place.
This is on an 09 Fatbob with 2000 miles.
#55
It is just like a shock absorber. If you have to compress a shock absorber to fit between 2 mounting holes, you no longer have the full range of the shock available.
#57
#58
For pete's sake.....'ain't a little shimmy 'an a little shake what "HD" is all about???? All the mods and washers and shims didn't do a fcukin' thing for any of you...I like it..the wife loves it...and the girlfriend "LOVES" it...if you want to get rid of the vibes...get a Honda.......
go smoke a doobie and chill out.... or better yet, since you don't know how this affected my bike, shut the **** up.
Performing the vehicle alignment procedure and THEN shimming the front motor mount removed a bunch of undue vibration. I had about 1/8" gap that I needed to make up. It's a bunch better... the bike also does not have near as much 'rear steer' that these newer dynas are notorius for.
#59
#60
... and that's not counting Nov. Dec. Jan. and Feb .... when I didn't ride because of the friggin snow.
