cleaning spokes?
Old 04-09-2009 | 06:20 PM
jkgraham's Avatar
jkgraham
Default cleaning spokes?
hello everybody i have an 08 fxdc anniversary and was wondering what is the best way to clean the wheels. they keep rusting..... just wondering what products you suggest and what methods you use to clean the wheels. thanks.
Old 04-09-2009 | 06:25 PM
jmpancoast's Avatar
jmpancoast
I am very particular.
I found the best way to clean spokes is with the least abrasive metal polish, a shoe string, and a lot of manual labor. Frequency in effort reduces the amount of effort necessary,
Old 04-09-2009 | 06:26 PM
Prodriverdon's Avatar
Prodriverdon
I pay to have it detailed just for that reason........the damm spokes, I have used a power ball on the drill that does work
Old 04-09-2009 | 06:36 PM
rdondes's Avatar
rdondes
Spokes rusting..? That sounds very unusual and shouldn't be happening. If I've ridden it, I clean my Harley once per week just as I clean my car once per week. It takes me 30 minutes to clean the bike and 10 minutes of that is for the wheels. I use mile soap (any kind will do) and the Harley spoke brush (HD P/N: 43078-00, http://www.harley-davidson.com/gma/g...bmLocale=en_US).
If the wheels are cleaned frequently, then they are a snap to clean. Remember, brake dust is corrosive. I have 14,000 miles on my spokes and the wheels look pretty good. It takes just as long to clean cast wheels and even longer if saddlebags have to be removed to get to the rear wheel.
Don't be afraid to get the bike wet. Use a hose, lots of soap and the Harley spoke brush.
Richard
Old 04-09-2009 | 07:09 PM
JRK5892's Avatar
JRK5892
shout... yep like the laundry stuff... spray it on, scrub them down and hose off... shine like brand new! been using it for years! tip came from an old timer when i was in college polishing a wheel in front of my fraternity house... saved me TONS of time!!! works great!!!!
Old 04-09-2009 | 07:31 PM
arkyrider's Avatar
arkyrider
6th Gear
This works really well. check out the strips.
http://www.lusterlace.com/moto.html
Old 04-10-2009 | 09:42 AM
speedjunkie's Avatar
speedjunkie
Aluminum foil and water. Yep, as crazy as that may sound. The spokes are cheap chrome and if they aren't cleaned RELIGIOUSLY, they will start to rust, due to mostly the brake dust. The stock pads are AWEFUL for rust!
Anyway, I had the same problem, and some of them on the front were fairly bad. Anyway, I found a blurb on the net about aluminum foil and water. I decided to give a try. VIOLA!!! Piece of cake! Took maybe an hour and they shine like new! Still some MINOR pitting, but not even remotely visible unless you REAL look close. Obviously the easiest way to do this is remove the wheel and brake rotor. Makes life alot easier.
Good luck!
Mike
Old 04-10-2009 | 10:19 AM
PigInaBlanket's Avatar
PigInaBlanket
so do you just get some aluminum foil and wet it and rub it on the spokes or what?
Old 04-10-2009 | 10:30 AM
2007fxdc's Avatar
2007fxdc
Best way I've found - get rid of the aggravating things...
Before:
After:
Old 04-10-2009 | 10:33 AM
anubisss's Avatar
anubisss
Shout! rules. Been using it for about a year now. My spokes are stainless steel so they won't rust. Spray on, use a paint brush to spread it around and hose off. When I get really bored I use a cloth and some metal polish.
Quick Reply: cleaning spokes?
