Plugging overfill tube okay?
Old 04-07-2009, 02:26 PM
Yonaton's Avatar
Yonaton
Yonaton is offline
Not Smart Enough To Be A Member of HDF
Default Plugging overfill tube okay?
I really hate that on my '09 FXD I can't fill to the top the gas tank. If I put even a little bit over the inner lip inside the tank, it will run out a tube that comes out at the bottom of the bike and makes a puddle.
Is it possible or even okay, to somehow plug the hole (or whatever the tube is attached to...haven't looked yet)? Will it cause any problems if I do plug it up? I don't do it often, but I want to be able to overfill when I know I've got a buttload of miles ahead of me and it won't be sitting in the sun any amount of time after filling it up.
Old 04-07-2009, 02:49 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Overfill
That tube is a vent and if you plug it the tank may not feed because it can't get air into the tank.
Old 04-07-2009, 03:31 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
+1 do NOT plug the tube.
Old 04-07-2009, 03:41 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
you will not get enough air in there, it will basicly create a vacume and no more fuel will go though... not good... undo it man, you can maybe get another .15 in there with it closed... just pull over and put in more gas, not to mention that all the fumes will build up and have no where to go!
Old 04-07-2009, 03:51 PM
compgeek789's Avatar
compgeek789
compgeek789 is offline
Get yourself a camp stove fuel bottle for a few extra miles. I rode through Death Valley last summer with my brother. He has a sportster with a peanut tank. Got a little worried about distances, so I brought along a pony bottle of fuel. We ended up not needing it, but it sure was nice to have for peace of mind. Even if it only adds 5 miles of range, that's 5 miles less that we would have had to walk through Death Valley.
I would never spend $120 on a leather holster for a fuel bottle, but this can give you a few ideas:
http://www.nashmotorcycle.com/index....rts/fuelslings
Old 04-07-2009, 04:16 PM
bberck's Avatar
bberck
bberck is offline
Like others said its needed as a vent.
How much gas you trying to get in there I have never had gas run out of mine. I can run over 200 miles on a tank if on the highway only.
Old 04-07-2009, 04:17 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
good to know...
Old 04-07-2009, 04:20 PM
dynarule's Avatar
dynarule
dynarule is offline
I aint never had gas run out of mine either. I even stand the thing up to get a little more in there. When i say full, I mean FULL!
Old 04-07-2009, 04:59 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
As mentioned above, don't plug it. If you plug it, it will create a vacuum in the tank and make it harder for the fuel pump, to pump fuel.
I always fill my bike on the side stand to the lower inner lip without any fuel going out the vent line, even after bringing the bike back upright. You might want to remove your tank access cover, it has a metal vent line attached to it that may need to be bent a little higher and forward.
If your looking to take some long trips without refueling you can get creative like below.
Old 04-07-2009, 05:32 PM
PG13125's Avatar
PG13125
PG13125 is offline
Don't do it, otherwise the gas won't flow
Quick Reply: Plugging overfill tube okay?
