Who makes 180 rear tire for Streetbob?
I have about 9K on mine and plenty of tread still left on it, so I think wear is based on riding style. If you have a HD dealer do the work there is a lot of work they do, following suggested installation instructions. So it will run you quite a bit of money. Follow the suggestions and have and indy do it. Much cheaper.
i got a tomahawk 55zr/180 for 82.00 just got home from lubbock texas 2000 miles round trip and no problems. i got about 5k miles on tire and still lot of tire left.
http://www.cycletires.com/products.htm
I now have a 160/70/17 rear tire that needs replacement. I'm going wider, called the Dealer and they say there is no 180....wtf? They say I can buy a 170/60/17, and they only sell Dunlop tires. I thought they made a 180. They also say they won't install anything but a 160, what it's called for. How do I get a 180 for a 06 streetbob?
Try shopping at Zanotti's or Chicago Harley for parts, and find yourself another dealer or independent shop if your not doing the work yourself. More info below:
http://www.chicagoharley.com/shop/
https://www.zanottimotor.com/shopping/pLookUp.php
I agree with what "AdrianVall" wrote above, I also didn't use the kit and dressed the wiring = no problem, but after an accident my original straps were damaged so I replaced them with the ones from the kit.
Here's some photos and info on the Screamin Eagle 180 kit, tends to look bigger with a chopped fender.
43197-04A Dunlop Screamin' Eagle GT502 180/60B17 Blackwall Tire 17" Rear $172.66
40502-06 Dunlop Tubes 17" Inner Tube 160/70-180/60-17 Center Metal Valve $20.24
43101-06 Dunlop Rim Strips Fits 17-inch Center Valve rims $3.48
59514-06 Rear Fender Inner side plate replacement bracket 2ea $9.87ea
4592 Screw 2ea $3.18ea
10065 cable strap 2ea $0.45ea
Prices from https://www.zanottimotor.com/shopping/pLookUp.php
