slip on exhaust
You wont have to do anything to the bike if you just change slip-ons.
If you do any modifaction to the air intake a re-map/retune will need to be done.
If you get a stage 1 map it's about $150.00
If you go with a race tuner the SERT will cost you about $450.00 along with 4-5 hours of labor on the dyno..
So that option will run about $800.00
If all you're changing is the slip-on mufflers, no other mods are required. If you put on a high flow air cleaner, such as the Screaming Eagle Stage 1 Air Cleaner (approx. $125) you'll also need to get some sort of fuel management. I have a 2007 FXDC and the Vance & Hines FuelPak (approx $275) works just fine.
Tanuki
Engine Mechanical Topics
10-26-2012 09:48 AM
