Tachometer Options
Old 02-09-2007, 11:54 AM
jmbear328's Avatar
jmbear328
jmbear328 is offline
Default RE: Tachometer Options
Here is the parts list:
Here is a parts list that I got from Zanottis for the CVO Dyna bar and gauge setup.
56973-07 CVO handlebar chrome $357.50
67880-94 Boot, reset switch $1.31
67925-04 Tapered mini tach Ga $13.88
67952-96 Gasket, Isolation, M $4.22
67956-96 Screw, Flat socket M $2.41
68953-04 Blackface mini tach $95.74
69853-07 Ring, Tach MTG $14.24
69854-07 Bracket, Speedo Mount $20.74
69855-07 Bracket, Ring, Indic $14.24
69868-07 Retainer, Indicator $2.54
71970-07 Wire Harness Instrument $166.00 at local dealer zanottis will be cheaper
46724-06 Diamondback brake cable $54.35
Total $747.17
I also used a chrome braided wiring housing cover purchased at autozone to cover all of the wires that I had to cut to give it a better look and I also bought a set of the H-D billet riser bolts and a set of chrome banjo bolts when I replaced the brake cable with chrome.
Old 02-09-2007, 12:23 PM
Blueghost's Avatar
Blueghost
Blueghost is offline
jmbear328
thanks for the info, I see a project in my near future.
Old 02-09-2007, 03:24 PM
jmbear328's Avatar
jmbear328
No Problem,..... just let me know if I can help out a bit. There was a couple things that were a lil tricky,.... mostly with the tach though.
John
Old 02-09-2007, 08:01 PM
TXSwede's Avatar
TXSwede
TXSwede is offline
I have ridden and owned LOTSA bikes. I don't recall many if any without a tach, What is the deal with not installing a tach on a big twin Harley-Davidson?! When I first sat on my Sreet Bob in the showroom I was shocked! Wheres the tach? Oh, this doesn't come with one. WHAT? Now, I'm no motorcyle engineer, but it seems like a glaring omission to me.
Old 02-10-2007, 04:29 PM
MAchonewon's Avatar
MAchonewon
MAchonewon is offline
I searched the vault for this thread trying to use good forum etiquette. I replied to an older forum. Any issues with the mini tach such as visibility, in the way of winshield, install etc.?
Hickey
07-05-2013 05:21 PM
Danzyg1
10-13-2010 05:40 PM
Davesurf
04-25-2008 08:00 PM
XLer8
03-29-2007 02:21 PM
arkieollie
01-23-2007 05:59 PM
Quick Reply: Tachometer Options
