Front turn signal relocation
Old 04-04-2009 | 11:52 PM
XKROME's Avatar
XKROME
front TS relocate for the cheap a$$ ****** F'r by yours truly
https://www.hdforums.com/forum/2535998-post13.html
Old 04-05-2009 | 02:03 AM
Doughboy's Avatar
Doughboy
i did the same thing.except i made the other side
Old 04-05-2009 | 02:54 AM
rockon's Avatar
rockon
Originally Posted by LeavenworthJeff
I just did a front turn signal relocation with Drag Specialities part 2020-0347. This same kit can be found in the JP Cycle book also. If you do a search on this forum lots of write ups on this subject. I didn't get the HD one due to it sticking out so bad. I almost did the same thing but quite a few people had mentioned this issue on here. Of coarse to each his own as well.
LeavenworthJeff
05 FXDI
Is that all you needed to make the change?
Old 04-05-2009 | 07:13 AM
dpriest's Avatar
dpriest
I did the same but used the chrome set from HD. They were about $20
Old 04-05-2009 | 08:03 AM
painguy's Avatar
painguy
How do I figure out what fork size I have? I have a 2008 fxdl, what mm. Thanks
Old 04-05-2009 | 08:24 AM
Black Bart's Avatar
Black Bart
Default Fork size
Yours are 49mm.
Bart
Old 04-05-2009 | 08:41 AM
painguy's Avatar
painguy
Thanks
Old 04-05-2009 | 09:42 AM
SC-Longhair's Avatar
SC-Longhair
I used the existing hardware to relocate the front signals. It's in the 'under $50' thread. Only thing you have to do is drill the hole out to 3/8" so it can accept the pinch bolt.
Old 04-05-2009 | 09:33 PM
LeavenworthJeff's Avatar
LeavenworthJeff
you will need the following if you want to use the original mounting bolts to the turn signals
2-5/16" lock washers
2-5/16" ss flat washers
2-5/16" nylon washers
see this link http://ae1m.com/relocate_directionals/install.htm
This worked out great this way for me. Thanks to Dynamite17 for the above link
LeavenworthJeff
Old 06-26-2009 | 09:31 AM
ggadwa's Avatar
ggadwa
Default Front Turn Signal Relocation
Ok so does the J.P. Cyles and or Drag Specialties Kit work on a 2009 FXDC?????
as Originally Posted by LeavenworthJeff "I just did a front turn signal relocation with Drag Specialities part 2020-0347. This same kit can be found in the JP Cycle book also."
Really like the looks of this method just want to be clear that it will work with the 09.
Just a bit slow on the up take here I guess.
GARY
Quick Reply: Front turn signal relocation
