True Track and Posi Track Fit Question
Will a True Track or Posi Track fit a 2008 Dyna that has a chin spoiler installed ? Since most of the Dynas handling problem originates from the way rear swigarm mounts would using just the rear part of the true track or posi track be of any benefit ?
Thanks >>>> Inthered
Yes they do but its not posted on their website.
Here's some more info:
https://www.hdforums.com/forum/dyna-...on-brakes.html
https://www.hdforums.com/forum/4395570-post119.html
http://www.dragspecialties.com/fatbo.../7731193?q=dxr
Iam beginning to wonder if my 2008 Low Rider even needs a true trac type of device. I have not been able to get my bike to wobble ever since I went with the 13 inch rear shocks and the heavier PS springs front and back. I also re-torqued the motor mount and triple tree bolts at the same time and the bikes been handling just fine.
Inthered
Inthered
Inthered
Inthered
If you can try someone's bike with a TT or Sputhe kit fitted, you will change your mind! These things improve stability as well as handling and make your bike ride a whole lot better. 400 bucks is not a lot for a lot of improvement. I have a kit on both my Harleys - there is no turning back!
a 07 Electra Glide and the only bike that he added the stabilizer on was the 07 he drives like a wild man and he said his 08 dyna was fine.
