probably a stuid quesion
Yeah, in retrospect the 150 bucks was not worth it.
If I had to do it over...... I'd probably do it again... 'cause it's just damn hard to have parts in the garage waiting for more parts to arrive before you can install them.... just doesn't work for me... ... so I did mods as I could afford. (slip on pipes, stg.1 a/c, and stg.1 download).
Its hard to say because there are so many different possibilities for stage 1. For example Thunderheaders will perform better then a short shots but they are both stage 1 upgrades.
It seems like your torque should be in the mid to low 80s though (at the wheel the HD site states crank numbers).
Received 4,770 Likes
Let's just say you install a free breathing air filter and let's say the air/fuel mix goes from an EPA required 14.7:1 to 16.5:1, then the dealer will remap your ECM back down to the EPA requirement. There are plug in fuel management devices that that can enrichen your mix. This will boost some power and bring the cylinder temps down a little.
