2005 valve seal issue
Old 03-25-2009 | 07:34 PM
mcdaniel52761's Avatar
mcdaniel52761
Default 2005 valve seal issue
Next month I'm taking the bike in for the 20,000 mile service and just learned about the 05 valve seal issue. Not knowing much about motors, is this something that if I ask them to check, they can do "easily? I've searched the internet but can't find any TSB or safety recall on it. Does anyone have a .pdf or a link so I can print it out and show the dealer? I do have the extended warranty on it so if it needs to be fixed, I'd rather get it done before it expires.
Old 03-25-2009 | 07:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I've exhausted my resources as to the TSB that covered the situation. The first question will be how much oil have you been using between changes? This was taken care of under warranty. Some 05's had the wrong seals installed, you'd use oil and foul plugs. The heads have to come off and valves pulled out. My old work order showed 4.5 hours in time/labor. If you get the work done and you have chrome valve covers spend the coin and get the chrome valve cover bolts installed.
Old 03-25-2009 | 08:00 PM
Sec Super Glide's Avatar
Sec Super Glide
15 k on mine and no problems yet when do these occur. What kind of miles?.
Old 03-26-2009 | 01:46 AM
mcdaniel52761
BTW, how much oil consumption are we talking about when there is a valve problem?
Old 03-26-2009 | 11:10 AM
seniorsuperglideE8
It's not the valves, but the valve guide seals. Many have had in excess of 1 qt. of oil consumed (burned ) in a 1k miles. The plugs will also so a heavy coating, oil soot on the them. If your plugs have been good and no oil consumption (or minimal) I wouldn't be too concerned. If you bike is out of warranty it would more than likely be on your dime.
stumpedmech88b
Engine Mechanical Topics
01-16-2018 11:00 PM
glide05
Exhaust System Topics
08-15-2016 04:44 PM
CW4_131A
11
03-20-2008 10:16 PM
glide05
10-22-2007 07:37 AM
Hog_fever
06-27-2006 02:11 PM
Quick Reply: 2005 valve seal issue
