2000 FXDL Electrics Question
Anyone know where I can find a downloadable schematic for the 2000 Low Rider electrics? Got a weird issue that started yesterday. Bike got hard to start after a bit of riding then wouldn't start at all, even after riding. Guessing it could be a loose battery cable or other loose wire somewhere that's not letting the alternator/generator to recharge the battery while the bike's actually running. It'd be easier for me to track that down with some kind of schematic to look at instead of just digging into it. Thanks in advance for any help on this.
Received 4,770 Likes
Go to the do your self help section here on HDF, then to electrical and look up the sections on charging. 1) if you on the original battery it's expiring on you, 2) with a good multimeter check the voltage going to the battery at 2000 rpm is it at 14.2v ?, 3) you may still have to do a charging diagnostics refering to the DIY part. The carb bikes between 99-2005 have a 2 phase stator system that is just keeping up with the battery requirements.
Thanks for your responses. After gettin' a manual (From Borders for roughly 1/2 the cost of gettin' it at the shop), it's been gently determined that it's not the connections but more likely the battery. Called in the use of my extended service warranty & it's gettin' looked at today. Thanks again for your help.
pjriebe
38
10-04-2011 10:43 PM
