black smoke from pipes
is it normal to have black smoke coming from the pipes when you 1st start the bike...what causes it and what can i do to fix it...would it be too rich on startup and would a new pc3usb map be in order.. if its a map thing would anyone have a map they would care to share.. my specs are 06 dyna se stage 1 breather kit, python bigshots,andrews 26h cams and stock ecm...thanks guys for any advice
Received 4,857 Likes
Black smoke= rich fuel mixture. Could be due to automatic choke when first firing up or it could be an improper fuel mixture.
Blue smoke= oil burning. This is when you need to worry.
Pull your spark plugs and check them out. If they are black, it is probably running rich, if they are white , you are running too lean and a light tan is a good mixture.
