Bought Namz bullet headlight, couple quick questions
1 Post
Hi,
I bought the Namz plug and play bullet headlight, (for 08 Wide Glide) it comes with the factory plug already installed.
Is there any way to get at the plug other than removing the gas tank? I'm thinking that the answer would be no.. I see the wire runs into the side of the fram then under the tank. There doesn't seem to be enough slack to pull it out from there. Any tips on tank removal?
Hi,
Is there any way to get at the plug other than removing the gas tank? I'm thinking that the answer would be no.. I see the wire runs into the side of the frame then under the tank. There doesn't seem to be enough slack to pull it out from there. Any tips on tank removal?
If not, and you have to get to the plug from the hollow under the frame, just raise your tank. No need to remove the tank. Cover your forward rocker box to protect it from the clamps on the cross-over fuel line. Unbolt the tank at the front, trying leaving the rear bolt in. This will allow you to lift the tank a couple inches. Hold the tank up by used a piece of wood under it.
Once the tank is raised, you can remove the plastic cover which sits under the front of the frame, beneath the tank. There are two tabs which rest in holes in the side of the frame. Push these tabs inward and the recess cover can be pulled down. It will take some maneuvering to completely remove this cover from the bottom of the frame.
Hopefully you won't have to go through all this. If so, I hope this makes sense and will help.
i just put a lamp on like that... you have 2 wires the headlight grounds to itself... red off the lamp goes to yellow on the bike, yellow on the lamp goes to white on the bike, black (ground) fromt he bike can get wrapped up tight... came out awesome on my buddies train! i cut soldered and shrink wrapped... better than stock... took me 15 min to do the whole thing... and drink a beer!
cmiller1014
05-20-2010 01:10 PM
