Should I try to install the Inner Primary Cover?
RE: Should I try to install the Inner Primary Cover?
Kevin, obviously there are a few steps that I did not take pics of when removing. Just follow the manual, and it's an easy job. To reinstall, just go in reverse, and make sure you use new gaskets, black RTV on the bolt threads, tighten the bolts to specs, reinstall the chain tensioner at the right tension etc.
Joe
Joe
ORIGINAL: Scout
Joe
Joe
Man, Joe. Thanks a ton for taking the time to post all of that. You don't know how much that helps me!
I'm going to print the pictures out for reference when I do the job. (Which will be soon). I'll keep everyone posted on how it went for me!
I've got another question here. I hope this isn't completely stupid.........
I've never had to torque a left hand threaded bolt or nut. I just noticed my Craftsman torque wrench will only torque right hand bolts or nuts.
What are you guys doing about the left hand nut that needs 155 ft lbs of torque?
renlan
05-08-2023 09:29 AM
