Should I try to install the Inner Primary Cover?
Old 04-27-2006, 02:23 PM
dyna2319's Avatar
dyna2319
dyna2319 is offline
Default RE: Should I try to install the Inner Primary Cover?
Excellant Advice, about taking a set back if things are not going together correctly. I usually polish some chrome or something to get over the problem. Still making the bike look nice and when it goes back together for your test ride you have a nice clean scooter.
Hog 2319
06 FXDWI with "some" mods and another sale at the stealer this weekend.
Old 04-27-2006, 02:32 PM
Scout's Avatar
Scout
Scout is offline
Kevin, where are you located?
I put on a chrome inner primary and it was a pretty easy job, just took a few hours. I took pictures of the complete job, and can post them if you want. I made my locking tool, and can mail you one if you want, but you can also make one real easy. I'm sure someone close by to you will lend you a big torque wrench if you need it.
Joe
Old 04-27-2006, 04:57 PM
racezilla500's Avatar
racezilla500
racezilla500 is offline
ORIGINAL: Scout
Joe
I'm in Western Kentucky. Those pictures you took might help me out! I like to get a good idea of what I'm going to see instead of just opening it up like a Cracker Jacks box and "surprise"!
Check your PM's too!
Old 04-27-2006, 05:35 PM
racezilla500
Also, are there any other chrome goodies that I should go ahead and put on since I'm going in that deep? Since I've got to take the starter out it sounds like it would be a good time to put on the chrome cover for it. You know, that kind of stuff!
Old 04-30-2006, 05:51 PM
racezilla500
ORIGINAL: jt1965
I think the part number on those sealing fasteners is 786a There are 5 of them.
Can anyone confirm this as the right part number?
Old 05-01-2006, 10:02 AM
jt1965's Avatar
jt1965
jt1965 is offline
I just took a look at my invoice that is the correct part number 786a. You need 5.
Old 05-01-2006, 12:49 PM
Scout's Avatar
Scout
Scout is offline
1. Boards, shifter and outer primary cover off.
2. loosen loctite with heat.
3. breaker bar on crank nut
[IMG]local://upfiles/313/7EB6BA5BC9914DA39C0CE03B49CF4922.jpg[/IMG]
[IMG]local://upfiles/313/1489C473D1944445BF987BCB7E1CA13D.jpg[/IMG]
[IMG]local://upfiles/313/6F113B3D8E2745E5A19E1AA8B5AE39DB.jpg[/IMG]
Old 05-01-2006, 12:57 PM
Scout's Avatar
Scout
Scout is offline
More to follow when I figure out what I'm doing wrong
Joe
Old 05-02-2006, 07:43 AM
racezilla500
ORIGINAL: Scout
Joe
Joe, that's good stuff right there! Thanks!
Old 05-02-2006, 10:15 AM
Scout's Avatar
Scout
Scout is offline
1. breaker bar on clutch hub
2. pulling off primary while holding compensating sprocket and clutch hub.
3. loosen and pull starter jackshaft. then remove starter from other side
[IMG]local://upfiles/313/7F674825B50747128F95037EA0A1A86B.jpg[/IMG]
[IMG]local://upfiles/313/C662FA8153124C55918F45DCDA2C11FC.jpg[/IMG]
[IMG]local://upfiles/313/5C54A4EB1E79483AA97D76BD75D9A0C7.jpg[/IMG]
Quick Reply: Should I try to install the Inner Primary Cover?
