rear performance shock comparison
Old 03-11-2009 | 11:37 PM
wolfydude's Avatar
wolfydude
Have the Progressive 440s fitted on my FXDC,think they are an amazing shock for my model,then again the roads are different here in the UK,but these 440s can def handle the twisties here.
Wofy
Progressive 440 Series, the ultimate Progressive shock with IAS - Inertia Active System. Clever enough to separate wheel movement from chassis movement so that your bike floats over the rough stuff, yet doesn't wallow in the twists and turns. Comes with hand-adjustable preload as standard, in a range of sizes and spring weights.
Old 03-12-2009 | 11:37 AM
MZBuckeye's Avatar
MZBuckeye
Originally Posted by blackmopar
do you need to space the fxdx shocks or are they dorcet bolt on? im not fearful of fabrication - just curious - Always wondered why they wouldnt fit truthfully.
im all about poor man alternatives - and this is exactly my intent for this post - get some idas flowin!
Special Ed - truth be known, i guess im not totally dis-satisifed with my hd412s (how much you weigh? Im 245 if I dont eat breakfst :')) and im runnign them on setting 3 - middle setting- but when I hit a good bump it sends me outta the saddle - addmittedly, this is coupled with a fricken ROCK of a front end that needs to be fixed.
Ive just been reading alot lately about true suspension - and how much it can help push harder - plus at the 11 inch height, i drag mid control peg around every corner!
They bolted right on my 05, but the seller I bought mine from included the upper mounting bolts because they were shorter than the upper bolts that were on my bike stock. With those bolts, I had 'em on in 30 mins.
Old 03-12-2009 | 05:19 PM
SPECIAL ED's Avatar
SPECIAL ED
I'm probably around 220 fully geared up and run my 412s somewhere around the middle position.I also have thier standard length progressive springs up front with 15 wt oil. I have noticed 2 things about the 11" 412s, 1, if you have the preload set too low they bottom out quickly and it rides like a rigid, and 2 they soften up over time and ride better than when new.In retrospect i wish I would have kept my 12 3/4" Electroglide shocks.
Steel Wheels
03-06-2015 01:23 PM
inswva
02-03-2011 03:43 PM
OutlawBagger
01-21-2009 09:33 AM
Z06_Pilot
08-21-2008 06:21 PM
twiceretired
12-02-2007 10:29 AM
