Shifter Shaft Forward Control Removal
Old 07-27-2009 | 03:51 PM
1919lrxc's Avatar
1919lrxc
The only thing that sucks it that the older kit is now more expensive that the new, and it only comes in chrome!
  #32
Old 08-21-2010 | 08:53 PM
CincyRider's Avatar
CincyRider
Scott db, thanks for posting that info! I bought the '06 forwards kit forthe '10 FXDC to put on this weekend. Got em on Friday but was very difficult to put in to neutral just moving the bike around. (didn't pull the primaries or change out the rear shifter arm)
I saw this thread and changed out the rear shifter arm, took about two hours but could've taken 5 minutes, I just wasn't working it right. Got the longer shifter arm on that came with the kit and was getting excited to finally ride with forwards on this bike.
As I moved the shifting rod under the tank and over the horn, the damn thing broke--snapped right off at the ball joint!
That rod is a piece if junk! Hope the dealership is open tomorrow...
Anyway it's not that bad, good to do if the bike's got issues finding neutral like stock.
  #33
Old 04-08-2011 | 02:46 PM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
I realize this post is several months old, but I have a question on the lever removal. I just bought a new FXDC and refuse to pay the dealer $300+ for labor for forward controls. I'd like to use the 06 and up kit. I have the lever loose enough to slide out on the shaft, but not open enough to rotate on the shaft and there's no way it's going to come off. When you opened up the lever clamp, was it loose enough to ROTATE on the shaft? I'm not sure how much I can open the lever up without breaking it. Thanks, AL
fasteddie
07-30-2024 08:20 AM
Ricketts
12-24-2014 11:15 AM
Altorr
07-22-2012 05:20 PM
mrtac2man
09-11-2010 12:01 AM
ny06fxdb
07-09-2007 03:52 PM
Quick Reply: Shifter Shaft Forward Control Removal
