06 fxdwgi post recall drama
Old 04-24-2006, 07:39 PM
mikehunthurtz's Avatar
mikehunthurtz
mikehunthurtz is offline
Default 06 fxdwgi post recall drama
any of you "dyna"miter's get that recall accomplished on your '06 yet. i did and it was going good until lube started leaking out of the shifter(where it goes into the tranny) any thoughts just for GP's?sounds like a gasket or seal.i wonder if it is related to to work on the recall or if it is a new issue. its going back to HD tomorrow
Old 04-24-2006, 07:47 PM
phreak's Avatar
phreak
phreak is offline
Default RE: 06 fxdwgi post recall drama
do you mean on the back side of the primary, where the shift shaft extends upward?
That area shouldn't have been effected by the recall.
I believe they accessed the tranny phrom the other side of the bike, removing the cover with "six speed" on it.
Old 04-24-2006, 08:39 PM
mikehunthurtz
yup when i read that recall bulletin fron hd(posted in transmissions primarys and clutches forum)it appears to me that the trans had to come apart. there was a lot more detail than i first thought about the recall[>:]
Old 04-24-2006, 11:38 PM
iwant1's Avatar
iwant1
iwant1 is offline
Yep, I've had mine done. I thought they created an oil leak as there were a few drops, but it was just some excess dripping off. No other issues at this point.
I noticed neutral is a lot easier to get now and has a much more positive click into it. Before it was pretty hard to get sometimes.
Old 04-25-2006, 12:48 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Mine was done at the factory before being shipped to the dealer. No leaks. Take it back.....they did it. There are no coincidences regarding oil leaks ever.
Old 04-25-2006, 01:40 AM
tb2377's Avatar
tb2377
tb2377 is offline
yes they have to take the inner primary. the dealer even tried to sell me an inner chrome primary since they were going to have it off anyway. take it back
[IMG]local://upfiles/7785/D2B0F20E397146A99F34FE67B6EA7380.jpg[/IMG]
[IMG]local://upfiles/7785/14634D84144241DEB2B1FD605018CCA9.jpg[/IMG]
[IMG]local://upfiles/7785/E4BE889A9EE0478386F5B8D314C349B5.jpg[/IMG]
Old 04-25-2006, 01:43 AM
HARLEY TECH#1's Avatar
HARLEY TECH#1
HARLEY TECH#1 is offline
2nd Gear
yep, im a tech, they have to pull the whole primary to take a nut in front of the pulley off to slide the tanny out, they did it
gasguy
04-05-2010 06:04 PM
Bob810
05-11-2009 10:15 PM
djw
04-20-2009 01:52 PM
06hdrider
08-25-2007 09:54 AM
dgriffith
06-13-2007 12:11 AM
Quick Reply: 06 fxdwgi post recall drama
