more PC5 questions battery removal?
Old 03-02-2009 | 10:52 AM
robertj74's Avatar
robertj74
Default more PC5 questions battery removal?
got my PC5 installed,not real happy with how crammed the harness is between battery and fuse box. I'm thinking of removing the battery and batt. box,to get a better look to clean this up a little. once I remove battery,what else besides the 2 torx bolts on top of frame need removed to get out the plastic box? Am I safe to assume disconnecting the batt. wont harm my PC map now that is installed?
THANKS
Old 03-02-2009 | 11:00 AM
bberck's Avatar
bberck
Not sure on getting the battery out but no it wont remove your PC map by taking it out.
Old 03-02-2009 | 11:08 AM
thedonthere's Avatar
thedonthere
I am going to suggest that you remove the battery AND battery box. Once you do that you will have access to all the wiring under the seat and you'll be able to better deal with your install. Its a piece of cake to remove and you'll see that you have plenty of room in there.
Don
Old 03-02-2009 | 11:09 AM
thedonthere
there are 2 torx on top and 1 in the center of the box
Old 03-02-2009 | 11:10 AM
octane's Avatar
octane
There is one more allen head bolt in the center of the battery box you have to remove. I pulled all the wiring harness off their plascic connector clips to clean up a little. They now sit side by side between the battery and fuse box. There is a lot of space infront of the rear fender part of the frame under the seat. I fit my turn/brake module, PC5, and my tail light circuit board under my seat with little problem. Just take your time.
Old 03-02-2009 | 11:11 AM
robertj74's Avatar
robertj74
Don
right on,man thats what I want to do what besides the 2 torx bolts on top of frame holds the box in?
Old 03-02-2009 | 11:13 AM
robertj74's Avatar
robertj74
thanks everyone!!
Old 03-02-2009 | 12:09 PM
coachstorms's Avatar
coachstorms
go to V&H website and watch the fuelpack install video, this may help you out some...
Old 03-02-2009 | 02:56 PM
Pythagrean's Avatar
Pythagrean
I was able to fit my PC5 under the seat on my Fat Bob. It worked out really well.
Gr3gIcky
02-18-2024 09:40 AM
Whiskyjock
03-21-2013 07:45 PM
SkeeterB767
10-31-2007 06:10 PM
CDR SEAL
03-16-2007 10:28 AM
Lasher66
02-23-2007 08:46 PM
Quick Reply: more PC5 questions battery removal?
