axle grease
Old 02-28-2009 | 05:34 PM
buellrider76's Avatar
buellrider76
Default axle grease
what kind of axle grease should i put on before i reinstall the rear wheel, aside from what harley will sell me.
Old 02-28-2009 | 05:40 PM
jsbridgew's Avatar
jsbridgew
I don't think you use axle grease. I'm pretty sure you simply use anti-seize lube.
Old 02-28-2009 | 05:42 PM
rounder's Avatar
rounder
Anti seize lube. Permatex.
Old 02-28-2009 | 05:43 PM
fixxr's Avatar
fixxr
You should'nt have to grease anything! the bearings are already sealed with grease in them.the axle should be cleaned and put in dry!
Old 02-28-2009 | 05:47 PM
xxxflhrci's Avatar
xxxflhrci
Yeah, you do that.....Sooner or later, you will end up with a BF'n hammer trying to knock you axle out. The factory doesn't grease the axles. Water will get in, they will rust, and the axle will stick to the bearings.
Anti-seize is what I use like the other guys. Grease will work fine if that is all you have on hand.
Old 02-28-2009 | 05:48 PM
Hx3's Avatar
Hx3
I just got done replacing rusted/galled bearings in my Ultra. I agree with xxxflhrci. I used anti-seize when I put mine back together.
Old 02-28-2009 | 05:52 PM
tlb's Avatar
tlb
you watched me remove my rear axle. nothing on it from the factory. now has anti-seize.
Old 02-28-2009 | 06:08 PM
fixxr's Avatar
fixxr
You may want to go to stainless steel axle's if you get a lot of water where you ride.they make things E-Z in the long run.
Old 02-28-2009 | 09:24 PM
buellrider76
my axle had a white lubricant, grease, compound of some sort when I removed it the first time, so it had whatever harley put on it from the factory. so there is no special stuff, it's just anti-seize lubricant?
found the answer.......thanks for the help guys!
Old 02-28-2009 | 09:30 PM
dyna rider's Avatar
dyna rider
Default Axle Grease ?
I put teflon high temp grease on mine. It's good for 600 degrees then I coated it with Permatex high temp anti seize. Had it out a couple of times since with no problem but always coat it with the high temp anti seize.
Quick Reply: axle grease
