Official Dyna service part# thread
That reminds me...I have 3 of these kits...STOCK Derby cover seal and three 'O' rings for the drain plugs...changed my Derby cover to one that uses the flat gasket so I dont need the 'belt' type seals any longer...I will give the seals to anyone who wants to pay for shipping....I will keep the 'O' rings....3 Derby cover seals for the cost of shipping...no more than $4....date on the pkgs is 07/16/08....
I added some
Rocker Cover Gasket (2)---------------17386-99A
Cam Cover gasket---------------------25244-99A
Bearing Housing Gasket (8 Hole)--------35654-06
cover gasket (little one that goes
behind the Clutch Release Cover 6 Hole)--36805-06
Gasket Service Kit (oil change o-ring kit)------17369-06
Dyna lift adapters---------------------72066-06
Outer primary gasket----------------------------------60547-06
Mid control shaft tower gaskets------------------------63869-06
Fork OIL SEAL (2)-------------------------------------46514-01
Fork SPACER SEAL (2)---------------------------------46515-01
All parts are for 08 Dyna
Belt Rear 131T (except Japan)-------------------------40046-07
Spark Plug--------------------------------------------32362-04
Spark Plug Wire Front---------------------------------31981-99C
Spark Plug Wire Rear----------------------------------31960--99A
Screw for Rear Seat that goes into fender--------------2952A
Front turn signal kit-----------------------------------68972-00
Battery-----------------------------------------------65989-97B
Pri Housing gasket service kit
Clutch cover gasket
O-ring for magnetic drain plug-------------------------17369-06
Exhaust Gasket (2)-------------------------------------65324-83A
Top End Gasket Kit-------------------------------------17052-99B
Engine Overhaul Gasket Kit-----------------------------17053-99B
Cam Service Gasket Kit---------------------------------17045-99C
Lifter Cover Gasket (2)--------------------------------18635-99B
Induction Module Service Kit w/
sensors/o-rings/screws/injector clips------------------27655-06
Intake Air Temp Harness--------------------------------69607-06
Stock Air filter w/ 29313-95---------------------------29191-08
Voltage Regulator ***.---------------------------------74631-08
Caddy for Regulator------------------------------------70464-08
Ignition coil------------------------------------------31743-01
Oil pressure Switch------------------------------------26561-99
Clutch cover gasket
My "trans-Atlantic" US$ 0,02
The devil gives birth to a Part Number List.
it's your baby.
git er done.
my contribution...................
it's your baby.
git er done.
................Owner's Manual......Parts Catalog......Service Manual..
09 Dyna........ 99467-09........99439-09A.........99481-09......09 Dyna
09 FXDFSE.... 99739-09.................................99525-09......09 FXDFSE
08 Dyna........ 99467-08........99439-08A.........99481-08......08 Dyna
08 FXDSE2.... 99739-08........99430-08...........99525-08......08 FXDFSE
07 Dyna........ 99467-07........99439-07A.........99481-07.....07 Dyna
07 FXDSE...... 99739-07........99430-07..........99525-07......07 FXDFSE
06 Dyna........ 99467-06A......99439-06A........99481-06A.....06 Dyna
05 Dyna........ 99467-05........99439-05A........99481-05......05 Dyna
04 Dyna........ 99467-04........99439-04A........99481-04......04 Dyna
add suffix for
..................Brazilian Portuguese......BR
..................European Portuguese....PT
..................Danish.......................DA
..................Dutch........................NL
..................French.......................FR
..................German......................DE
..................Italian........................I T
..................Korean.......................KO
..................Norwegian..................NO
..................Polish........................PL
..................Simplified Chinese........ZH
..................Traditional Chinese......TW
..................Spanish.....................ES
.......DoubleCheck and Verify with your source.......
My to this database:
2003 Dyna models Service Manual: 99481-03A
2003 Dyna models parts catalog: 99439-03
2003 Dyna models electrical diagnostic manual: 99496-03
2003 Dyna Police parts catalog: 99544-03
2004 Dyna Police parts catalog: 99544-04
parts manual owners:
2001 Dyna modelssharkey
2003 Dyna Models.............FXD2003Rider
2003 FXDP.......................FXD2003Rider
2004 FXDP.......................FXD2003Rider
2005 Dyna models.............Baeseman1
2006 Dyna models.............mud
2006 Dyna models.............jmpancoast
2006 Dyna models.............WS6 Formula
2006 Dyna models.............thedonthere
2006 Dyna models.............Wonkaboy
2007 Dyna modelsr............dondes
2007 Dyna models.............SC-Longhair
2007 Dyna models.............skip3406
2008 Dyna models.............lonewatie
2008 Dyna models.............bberck
2008 Dyna models.............B's Fatbob
2009 Dyna models.............HalfCap
service manual owners:
2003 Dyna models.............FXD2003Rider
electrical diagnostic manual owners:
In need of 2003/2004 p/n's info? ===> shoot me a PM!!
FXD2003Rider
Thanks for the original reply but I never got it. Would you mind posting it again?
Thanks.
Thanks ahead of time!
