Temporary Bob job (with pics)
the front fender is tite! You did a great job mocking that up. I wouldn't make any rsuh decision until you get the old stocker back and see it mounted, I think you may change your mind....
Overall, it really looks sharp. That seat is the one I've been looking at, does it move you back, forward or, keep your original position?
Here is a pic of the rear fender straight on. I haven't mounted turn signals yet, which I think are going to look a little off. I have the quick release sissy bar set up, so the lights will be out a little ways. I drilled out holes 1" above the stock ones and cut right on the line connecting the tops of the stock holes, so the fender is sitting 1" lower than stock. I think it turned out pretty clean. I hated the look when I just cut the rear and left it at stock height. I haven't had any bottoming out issues yet but I am running 412 hd's.
Riley: I see you are in the CVMA. Is your first name Brandon? If so I think we were in 1-7 CAV together in OIF 2.
