On the 09s it just says 32 oz, which is what I'm going to put in.
My '08 manual says the same, but that's only correct for initial fill. You'll never get it completely empty via the drain hole. The correct level for refills is to just overlap the bottom of the clutch diaphram (with the bike vertical). Mine took 27oz to get to the that point. Overfilling can cause slippage and difficulty finding neutral.
My '08 manual says the same, but that's only correct for initial fill. You'll never get it completely empty via the drain hole. The correct fill level for refills is to just overlap the bottom of the clutch diaphram (with the bike vertical). Mine took 27oz to get to the that point. Overfilling can cause slippage and difficulty finding neutral.
Well, my 09 manual (page 93) says the "dry" (initial) fill is 40 oz and the "wet" capacity is 32 oz.
Those numbers are guidelines, not absolutes. I'm just trying to save you some grief and having to do the job over again... but feel free to ignore and dump in the whole 32oz.
