triple tree question
I am a little confused. I have an 05 lowrider and I was thinking about putting some chrome triple trees on it. I want to get HD part # 45023-02 which is supposed to be the same trees as stock, just in chrome. The HD site says that a bearing kit needs to be bought with it. Is this correct? If they are the same trees I already have than why do I need a bearing kit? Also, I know my lowrider has more rake than the other Dyna models, is this because of a different frame, bearing cups, trees or what? I to make sure I am not going to lose rake if the trees are actually different from what I got.
It is generally considered good practice to replace your bearings & races as a set. The bearings & races over time & miles will "wear" in together. It probably depends on how many miles you have on your bike. The rake on a lowrider is in the frame.
When I converted to a stock wide glide front end I replaced the bearings & races, I had about 65k miles on my bike at that time.
Your call, personally if I've got the whole front end torn apart I might as well do a little preventative maintenance.
bearings
replace the bearings,,,,the lower bearing is pressed on the lower tree assembly,,,easier to replace than get off unless you have a bearing puller,,,,
also go with aftermarket bearings,,,i found some for my 06 for 20.00 cheaper than the stealer,
only had to get the lower dust cover from the stealer for a couple of bucks,,,,,
I was going to order the trees through Chicago HD. The bearing kit they call out for is $22.40 with the 20% discount. I didn't think that was too bad.
Believe me, I have. I wanted to go with a set from Vulcan and change to a midglide like you did. It's $450 for their kit and then I have to get a light ($100 - $200) and something to do with the indicators. I saw some great ideas on the forum on what to do with the indicators. Money is getting tight for the bike. I have earmarked $2000 to put into it and more than half of that is going into paint and the rest I planned on getting chrome pros to do the wheels. I am about to put it into the shop for street slammers, chrome sliders, tires, and a few other little pieces I have as well. Its gonna cost me about $450 to do that alone. I already the parts. I thought I would put the trees on it while I had it apart. I can get them for about $160. I haven't fully made up my mind yet but I have to do something soon. My front is wore out and we have an annual trip to Key West coming up in a month.
traveler
02-22-2007 02:26 AM
