SE 110 heads
Question - would the 110 heads fit the 96 jugs? I was thinking the engine cases had to be bored to accept the 110 jugs (and therefore the 110 heads may not work with 96) ... may be off base on that ... or thinking of another aftermarket build vice 110 ...?
Something to check first if you've got a real prospect of getting the 110 heads.
R/
Priest
R/
Priest
What used to be a 1550cc kit will make your motor a 103ci mill.
Does that include the case-boring jig? I maintain that the last 7 cubes doesn't justify the cost of boring the cases. If you just have to bore the cases , go for an Arias 107 cid piston kit. If you go that route , see Jon Miller at Thiel's Wheels. The last dyno file I saw on his drag bike was 359 horsepower.
zenmedic
Exhaust System Topics
44
12-31-2008 08:45 AM
Base401
12-04-2008 11:10 PM
