Tank Lift Confusion??
Old 04-21-2006 | 10:27 PM
rickshog's Avatar
rickshog
Default Tank Lift Confusion??
Ok... read all the posts on it but I dont get it.... I think I want to do the 3" lift on my 06' dyna. Has anyone done this peticular bike?? If so and it works can someone scan in the parts they made so I can cut my own?? Im at work now so I cant see the bike and I dont even know what size holes to drill... Any help is appreciated THANKS!!!
Rick
Old 04-21-2006 | 10:58 PM
phreak's Avatar
phreak
Default RE: Tank Lift Confusion??
RudeDog has made it kit.
I think a couple people on here are using it on their 06s. He's making one phor me also.
Old 04-22-2006 | 01:57 AM
intruder400ex's Avatar
intruder400ex
If your asking those questions then you didnt read all the posts so ill get them for you there is detailed info on how to make and install the tank lifts.
https://www.hdforums.com/m_311700/tm.htm
https://www.hdforums.com/m_363372/tm.htm
There is one more thread that I cant find ill look again later.
steve
Old 04-22-2006 | 02:22 AM
WgSkee's Avatar
WgSkee
rickshog...Basically the metal piece you need is 1" wide 1/8" thick. Since I don't know if all of the tanks have the same mounting bolt size, I used the same size that originally mounted mine.. (I have a 2006 FXDI ).. I went to LOWES and bought a new pair about 1/2 " longer than the original. The reason I did that was since my new metal piece was straight not offset I needed to place two washers on each size of the bottom tank frame mount to take up the space that an offset piece of metal would normally occupy. The top mount (on Tank) didn't need the extra washers. The metal I used where just wall or shelf corner brackets that I bought at WALLY MART they had pre-drilled holes. I first used one bracket that had pre-drilled
holes spaced at 1 3/4" .. I just changed out those with a set that had 3" holes... worked great only had to move my throttle cables around a little for better clearance. I also rounded the ends with my grinder and painted them.. One problem I had was stupid me I had just filled my tank..... I emptied it out.. that was a pain... I cut the fuel line that ties the two sides together and put a longer one in to give me the 3" lift... between this post and my other one I think I pretty much covered it... I like the effect it gives the bike... I'd take some pics but my digtal camera bit the dust the other day....Oooooops..
Old 04-22-2006 | 10:50 AM
intruder400ex
here are some pics from my sh1tty camera up close, and dont forget you will need a length of vaccum hose also.
steve
Old 04-22-2006 | 11:16 AM
rickshog's Avatar
rickshog
Ok... startin to get it... thanks guys... When I get home ill start pluggin away at it and get some pics on here. See ya
Rick
Old 04-23-2006 | 12:42 AM
WgSkee's Avatar
WgSkee
intruder400ex and rudedog... Thanks.. Went to a HD Birthday party today a few friends seen my lift thought it looked great... a couple of guys that I didn't know said it looked cool... another guy said my fuel gauge will be f'cked up and another said it looked like a sportster... I think it looks way better than the original setup...
Old 04-23-2006 | 02:11 AM
intruder400ex
Aparently the one guy doesn't know how a HD fuel gauge works, The other guy must have never seen a sportster and any dyna for that matter standing next to each other. The only thing that matters is do you like it, **** the rest!
steve
Old 04-23-2006 | 06:27 PM
WgSkee's Avatar
WgSkee
[sm=youreright.gif] I like it... Hmmmmmm... I think I may try to get it a little higher....
Old 04-23-2006 | 06:42 PM
rickshog's Avatar
rickshog
hey guys thanks for all da help.. Should have it done this week... Weather in NY sucks but I guess I cant complain cuz we have had our fair share of good weather as of late.
Rick
07bobber
01-08-2011 11:07 PM
AdrianVall
12-15-2009 05:49 AM
ehc0720
04-06-2008 10:54 PM
warren888
06-06-2007 01:00 PM
PhatHarley4Me
01-19-2005 09:08 PM
Quick Reply: Tank Lift Confusion??
