Dumb Question of the Day... Tuners
Old 02-12-2009, 12:02 PM
ct555's Avatar
ct555
ct555 is offline
Default Dumb Question of the Day... Tuners
Hey guys,
Ok, can someone explain to me the deal with tuners. My father just replaced his old stage one with a new heavy breather. I was thinking I could take his old stage one and put it on my fat bob. Seeing as the tuner does not stay with the bike, could I then use his tuner on my bike? Basically sharing one tuner, saving me the cost of going out and buying my own to sit in the basement as his does.
I feel that I'm missing some understanding on how these things work.
Old 02-12-2009, 12:04 PM
bberck's Avatar
bberck
bberck is offline
I beleive all the tuners that do not stay on the bike still lock to that bikes ECM and cant be used on others.
Old 02-12-2009, 12:40 PM
2007fxdc's Avatar
2007fxdc
2007fxdc is offline
I believe bberck is correct from what I've heard. Are you just changing your a/c or do you have aftermarket exhaust as well? Chances are you'll need to buy something separate.
Old 02-12-2009, 12:44 PM
ct555's Avatar
ct555
ct555 is offline
Planing on changing the exhaust as well...
Old 02-12-2009, 12:47 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Which tuner are you referring to?
Old 02-12-2009, 12:49 PM
rounder's Avatar
rounder
rounder is offline
your gonna want your own individual tuner. No two bike can usually be tuned the exact same way. Get a TTS mastertune, SERT, or PCV. and get your bike dyno tuned by the best you can find.
Old 02-12-2009, 12:54 PM
anubisss's Avatar
anubisss
anubisss is offline
It all depends on what tuner it is. Power commander can be swapped no problem. From what I read sert cannot. If you are just talking about and air filter setup it depends on what bike it came off of and what bike you have.
Old 02-12-2009, 01:02 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Tuners
I might be wrong but Harley's stage 1 is intake, exhaust, and a download to the ECM. No "tuner" involved. Their SERT (Screaming Eagle Race Tuner) is married to the ecm and cannot be used on any other bike. Other "tuners" like pc (power commander) will work on any bike with a ecm and can be moved to another bike.
Old 02-12-2009, 01:39 PM
ct555's Avatar
ct555
ct555 is offline
He has the SERT. I was looking at using his old stage one, and putting the V&H BR 2-into-1 on. The stage one would be coming off a 2006 street glide and going on a 09 fat bob.
Old 02-12-2009, 03:24 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Ok first of all his SERT will not ever work on any other bike.Second his "stage one" download was just that a download to his ECM or fuel injection and could not be transferred to another bike.Now if what you're refering to is his stage one air filter that could indeed be used on your bike but would probably not run very good without some sort of modification to the Fuel injection I.E. a stage one download, SERT,PC5,TFI,IED whatever.
Quick Reply: Dumb Question of the Day... Tuners
