Motherwell's Solo Luggage Rack
My motherwell doesn't wobble at all. Like sniper said tighten the bolts. You really have to put some weight on it to make it move. I had my roll bag on there and my work laptop strapped to the top of it and I have a 32 mile one way and did fine. That was the first test with any weight. I don't know what the deal is with the mounting trick with a zip tie. I just got another female attachment that you screw your solo seat into and installed into the rear section where you put the screw for a 2up seat and got an extra screw and screwed it in. Nothing special. I got more pics in my album, but heres a close up.
Here's the foam pads. As you can tell my bike is black and no scratches or dents from this rack.
Jaron,
The zip-tie thing I was referring to is an easy method to install the 2nd female fender nut. Not for mounting the motherwell. Sorry, I wasn't very clear. I think the H-D fender nut "kit" comes with a zip-tie for the install, if I remember correctly. It's been a while...
Perch,
My attitude stick is also the CycleVisions 18" stick. Like DeathProof, I had a fantastic experience purchasing from them. You can buy the stick from other distributors for a few bucks less, but you'll actually save money if you buy from CycleVisions directly. If you ask nice, they'll powder coat it whatever color you want for free Good luck getting that kind of service from J & P cycles, etc. Also, be sure to ask about the fittment with your Easy Brackets. I don't know if it will fit, but I'm sure those guys can tell you. They were super helpful and seemed very knowledgeable. Give them a call and I'm sure you'll get the help you need.
Cheers,
J
Perch,
Cheers,
J
Jaron,
[QUOTE=sniper77;4530178]It doesn't come with anything except the adhesive-backed rubber under the rear connecting point.
Here's the fender bib but I don't have a pic of the luggage rack on it that I find. It protects the fender from any scratches form the bungee cord hooks as well so it is well worth the $25.
Did yoh use any specific mounting bolt? I was going to get the black ones from motherwell. The reason i ask is because i imagine that the fender bib adds thickness and was just concernec that i would not have enough thread left to tighten securely once i attached the rack over the bib and rubber pads.
