does anyone have ideas for a backrest
Its great!
http://www.protac.net/7501.html
i've got a Lazy Rider that is really great on the long rides. sure makes my back feel a whole bunch better, and allows me to stretch out and enjoy the ride.
http://www.lazyrider.com/
I was able to make my own backrest for a solo seat. This project only cost me about $10 (spray paint, bolts, and a 3' piece of steel from a home improvement store). This took me about 8 hours to bend the piece of steel into shape so that it fit me and the bike perfectly. Before this project I had a stock 2-piece seat with a detachable backrest. For materials I used my stock Street Bob seat, Harley passenger backrest pad, and a 1.25" wide piece of steel (thicker gauge).
1. I separated the two seats from one another
2. I then took my passenger backrest pad off of the bike.
3. I took the flat piece of steel and held it against the bottom of the stock street bob seat so I could get an idea of where I needed to drill a hole in the piece of steel (attach to bottom of seat pan) and to get an idea of how far I would need to bend the piece of steel to get the right angle for when the backrest pad would be attached later.
4. I then drilled a hole in the piece of steel and bolted it onto the bottom of the stock seat.
5. I carefully shaped the piece of steel until I got the correct angle so that the backrest would be in the perfect position for me. This process took the longest. Prop it onto the bike every now and then to check the bends. Be patient. Make sure that the piece of steel does not contact the rear fender at all as it will get scratched.
6. Once I finally pounded the piece of steel into shape (with a hammer) I drilled a hole into the piece of steel and bolted the passenger backrest to it. You can use either a solid work bench and clamp the piece of steel to it or you could use a vise. I just used a solid oak block as I did not have the luxury of a work bench or vise. Hey whatever works!
7. I then marked a line as to where I would cut the extra steel off; as it is not needed.
8. Prop it onto the bike and check for any last adjustments; make all adjustments.
9. Get a grinder and make it nice and pretty.
10. Primer and paint.
I was not able to keep the passenger seat on the bike with this setup but it works great for riding solo. When I ride two up I just take the bracket off that I made and then bolt the two seats back together.
I also use a smaller, shorter Tbag for shorter trips. Again I can put a few items in the bag such as extra gloves, towels or whatever, just to fill it up for the support.
But eventually I do want to get a seat with a rider back rest, but like everyone says, they are NOT cheap.
