Torx Bit Question
Sears has a inexpensive brand now that isn't too shabby.
Rack of the standard sizes run about 10 bucks.
The ones that you need for many of the little things would be T25 and T27.
The latter is the one size that normally does not come in a standard set though.
I found a set made by Isle that is old at Sears that includes this size.
http://www.shopperschoice.com/item_n...source=froogle Whole set for 47 bucks shipped. I never ordered from them though so can't speak of there store. OTC is tops in my opinion.
http://www.thetoolwarehouse.net/shop/LIS-27200.html here is a lisle 12 piece set for 23 dollars. Lisle is pretty good stuff.
You get one of them you are pretty set unless you need a T70 or some oddball T size. Also these are not tamper proof torx, I don't recall seeing any tamper proof torx on my 06 WG but there may be some. Tamper Proofs work for regular Torx.
http://www.thetoolwarehouse.net/shop/LIS-26530.html Lisle tamper set with larger regular torx for 20 bucks. Probably the least expensive best coverage option. I have ordered from these guys and I am pleased with there ship times.
http://www.thetoolwarehouse.net/shop/OTC-6145.html OTC tamper proof set. Doesn't have the larger Torx sizes though.
