Oil - Opinions from Dyna Riders
Old 02-08-2009, 09:25 AM
shawn e.'s Avatar
shawn e.
shawn e. is offline
Default Oil - Opinions from Dyna Riders
I am gonna change oil in all 3 holes. I have been searching the tech sections for a while and seriously I am kinda blown away with all the choices. What do you guys who wrench on your own bikes use! My last two engine changes were HD oil. I think I am gonna go synthetic. Do you guys use ATF in the trans?
Thanks In advance
Shawn
Old 02-08-2009, 09:37 AM
donr101395's Avatar
donr101395
donr101395 is offline
Lucas 20/50 motor and primary. Lucas 75/90 syn gear oil in the trans. Wix oil filters.
Old 02-08-2009, 09:38 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
You will get a bunch of answers!
I use Mobile 1 V-twin 20/50 in the engine. Redline HD shockproof in the tranny, and HD formula in the primary case.
ATF is only for automatic transmissions. You need a heavier gear type lube, for gear to gear setups.. gear to gear = heavy shock load on the meshing gear tooth faces.
Basically, a good synthetic for the engine: Mobil 1, Amsoil..... A good synthetic for the tranny: Redline, Mobil 1, Amsoil, and a good basic dino for the primary. The reason for not using a synthetic in the primary, is it may cause clutch slippage because synthetic oils are a bit more slippery.
If you are going to use a filter other than Harley premium, make sure that it handles down to 5 micron. Harley filters do... not sure about the others.
Old 02-08-2009, 09:42 AM
MZBuckeye's Avatar
MZBuckeye
MZBuckeye is offline
Redline in all three. I use their V-twin engine oil, Shockproof V-twin trans oil and V-twin primary oil, and HD filter.
I order it all from here: http://www.racerpartswholesale.com/c...y/Red_Line_Oil
(except for the filter of course)
I also use Redline in my car's transmission, transfer case and rear diff.
Old 02-08-2009, 09:50 AM
kk6pg's Avatar
kk6pg
kk6pg is offline
That issue is up for debate too. I run synthetic (Royal Purple) in the primary specifically for that reason. If you do a lot of slow speed maneuvers, or are stuck in rush hour traffic, slippery oil is cheaper than a clutch.
Old 02-08-2009, 09:51 AM
ko4qc's Avatar
ko4qc
ko4qc is offline
Amsoil 20-50 in the case and primary.HD transmission oil in the gearbox.Amsoil filters.
Old 02-08-2009, 09:55 AM
archergodwin
Really good point.
I guess it would depend on what your major mode of operation is: mostly in town (more clutch action) or mostly cruising (less clutch action).
Old 02-08-2009, 10:00 AM
Gary7's Avatar
Gary7
Gary7 is offline
That's really an old wives' tail that has been disproved many, many times.
There may be other valid reasons not to use a particular synthetic fluid in the primary, but the fact that it is synthetic (be it primarily PAO, Group III Hydrocracked, or some combination of both) is not one of them.
Old 02-08-2009, 10:19 AM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Thanks In advance
Shawn
This is what I use below:
Amsoil 20W-50 in the engine & primary
http://www.amsoil.com/storefront/mcv.aspx
Amsoil Severe Gear 75W-90 in the trany
http://www.amsoil.com/storefront/svg.aspx
AMSOIL Preferred Customers SAVE
http://www.amsoil.com/a/wholesale-preferred-customer
Harley oil filters P/N 63798-99A (chrome) or 63731-99A (black) from
http://www.chicagoharley.com/shop/
or
https://www.zanottimotor.com/shopping/partLookUp.html
Old 02-08-2009, 10:20 AM
trip20's Avatar
trip20
trip20 is offline
Here's what I'm running.
Engine
Transmission
Primary
Quick Reply: Oil - Opinions from Dyna Riders
