H.D. 10 Row Oil Cooler
Old 02-11-2009 | 03:56 AM
wide06glide's Avatar
wide06glide
Nice score, and great pix!
  #32
Old 02-27-2009 | 07:50 AM
WS6 Formula's Avatar
WS6 Formula
A little detail, aluminum tape trim:
  #33
Old 02-27-2009 | 09:55 AM
dyna rider's Avatar
dyna rider
Default Front Motor Mount
I just shimmed the front on my bike 2 days ago. The vibrations were so bad I was convinced the mount was bad. I ordered a new mount and proceeded to change it out. What I found was that the mount was a 1/2" away from where it was supposed to bolt to the frame. I searched until I found shims to fit the mount instead of using washers. I'm sure the washers will work well but I have used shims in my profession so I wanted to shim this mount up. I found the shims at Grainger Supply Co. There is one in town here so I didn't have to order them. If you don't have one near it's www.grainger.com These are stainless steel and are .125" each so it took 4 to do the job. I also had to buy longer bolts to get the mount attached again. Those were polished stainless from Ace Hardware. The two bolts with polished flat and polished lock washers were expensive @$17.00 and the shims were about $7.50 at Grainger.
  #34
Old 02-27-2009 | 09:58 AM
dyna rider's Avatar
dyna rider
Default Pics
Forgot to add these
Attached Thumbnails H.D. 10 Row Oil Cooler-shim.jpg   H.D. 10 Row Oil Cooler-shim-box.jpg
  #35
Old 02-27-2009 | 10:23 AM
ehc0720's Avatar
ehc0720
About the mount, I think whoever said that when adjusting the mounts that the bike should be upright and with rider weight on it because it is attached to the rear suspension hit right on it. I took my WG to the dealer because of excess vibration after the 1000mi service, they over tightened the mounts I believe. Anyway I got the normal runaround about "that's the way it is suppose to be", I stood my ground and they called their HD service rep. He faxed them "new" instructions for adjusting the mounts. Basically it was to strap the bike down to the lift, maybe this was to simulate the riders weight, then loosen the mounts and run the motor for a few minutes this allowed the motor to "center" itself. Then turn it off and torque the mount bolts. This worked great the bike is smoother than ever and smoother than others I've ridden. Also, there were no spacers used.
  #36
Old 02-27-2009 | 11:03 AM
jarhead45's Avatar
jarhead45
good info on oil cooler
  #37
Old 02-27-2009 | 12:12 PM
NoLongerAmember's Avatar
NoLongerAmember
Originally Posted by WS6 Formula
Yes but, ideally you probably would want the bike upright with rider weight, considering that the rear mount is tied into the rear suspension.
Is this how you "relaxed" your mount?
When you did this, did you just have the bike leaning on the jiffy or upright on a lift with most of the weight on the wheels or off the wheels?
Thanks, CB
  #38
Old 02-28-2009 | 09:29 AM
WS6 Formula
Thanks, CB
Kind of, I had the bike on the side stand when I removed my vapor canister (https://www.hdforums.com/forum/337637-post6.html), thats when I noticed the preload on the mount (the mount pulled away from the frames cross brace). With the the two bolts loose to the frames cross brace, I then put a jack under the engine and jacked up the engine until the two bolts could turn freely by hand, then I measured the gap and shimmed.
Later on I did the engine alignment as per the factory service manual. With the bike upright with my wife sitting on it to hold the bike upright (not quite near my weight). I loosened all the mounting bolts and ran the engine for about a minute, then used loctite threadlocker and torqued all the bolts.
When I installed the oil cooler I rechecked the gap and used the same shims as before.
  #39
Old 02-28-2009 | 10:35 AM
NoLongerAmember
Thanks for the update, CB
  #40
Old 11-27-2010 | 12:31 PM
gdt3's Avatar
gdt3
WS6, you obviously have high standards and take pride in your work. Nicely done.
Cheers,
Don
Quick Reply: H.D. 10 Row Oil Cooler
