BRIGHT headlight Who????
Old 02-01-2009, 12:53 AM
Pythagrean's Avatar
Pythagrean
Pythagrean is offline
Originally Posted by JaronB
Just pull the bulb and take it into the autoparts store. I just got back from buying one, but I have the h4s Don't know what the fat bobs have.
I live in a very small town and we have no good auto part stores. I usually have to buy everything online.
Old 02-01-2009, 04:33 AM
Rauzer's Avatar
Rauzer
Rauzer is offline
Any of you guys have an issue with the chrome on the inside reflector with these hotter bulbs?? I bought an aftermarket light from EP and within a few months the chrome bubbled on the inside. They replaced it, and within 3 weeks I could see it happening again. I swapped out the piece with my stock one and it seems to be ok. Just wondering...
Old 02-01-2009, 04:55 AM
7373pisces's Avatar
7373pisces
7373pisces is offline
A High Density Bulb..I had one put on..Big Difference to the standard one..Very good for Highway! or any road. I recommend this bulb.
Old 02-01-2009, 06:11 AM
yoseppi's Avatar
yoseppi
yoseppi is offline
got a part number or link for this bulb?
hopefully not as expensive as this one. http://*******.com/bstf2f
Thanks
Originally Posted by dlstanf2
I got the PIAA Super White Bulb. WORKS GREAT!!!!!! Well worth the investment. It's a little more expensive since it designed for a motorcycle and the vibration it endures. The element is much thicker.
Be sure NOT to touch the bulb when installing. It has a bluish tint to the beam. But it will LIGHT THE ROAD.
Others are using the Silverstar H4. It's $20 cheaper.
Old 02-01-2009, 07:13 AM
mtairy biker's Avatar
mtairy biker
mtairy biker is offline
I have had PIAA and they are a great bulb but i found a cheaper one a candelpower bulb
i have them in both bikes they are a german bulb they work very good also
when you install these type of bulbs i was told to take the rubber boot off and leave it off it trapes heat and that is a bulb killer and could melt
Old 02-01-2009, 09:08 AM
dlstanf2's Avatar
dlstanf2
dlstanf2 is offline
Here,s a link to Knee Draggers where I got mine. I was concerned about "heat" & "vibration" also. This bulb only draws enough current for 60W(H-Beam) & 55W(l-Beam). A high current draw will heat your wiring and put a lot of heat into the headlight.
Also, my Dyna had vibration problems but the bulb has held up. The price of the bulb is $48.50. The FatBob with it's twin 4" light and closed nacelle might be a different issue.
I have not seen any damage to my reflector, but I will pull the headlight nacelle to check the rubber boot. Had mine for 2 years now.
[url]http://www.kneedraggers.com and do a search for "PIAA H4 Extreme White Headlight Bulb - 60w/55w"
Last edited by dlstanf2; 02-01-2009 at 09:10 AM. Reason: change link location & added search
Old 02-01-2009, 09:36 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by Pythagrean
Anyone have the part number for a Fat Bob for Sylvania Silverstar. I would love to brighten up my headlights.
I have a pair of H13s in my FatBob and they are a great upgrade.
Old 02-01-2009, 04:41 PM
reesmicm's Avatar
reesmicm
reesmicm is offline
Default Fat Bob headlights
Haven't opened up my headlight bucket yet, but looking in the "parts manual", it looks like two different lights: one straight plug - left (68329-03) and one L-shaped plug - right side (2 part #'s 69838-08 or 68881-01). I think the euro light doesn't have both light up at once, so the euro right might be single filament high beam.
Looking in the "service manual" they list domestic (69838-08 x 2) and international (68881-01 x 2), so the 68329-03 no clue.
Guess need to open the housing and what is true
left/right - sitting from rider position
As someone mentioned, the bucket size in a FatBob might be of concern for using some of the aftermarket lights. Usually the higher quality brands like PIAA put out less heat.
Any comments?
Old 02-01-2009, 06:40 PM
Dutch550's Avatar
Dutch550
Dutch550 is offline
I have had complaints that my stock fat bob lights are too bright. I have been flashed many times by oncoming traffic. Everyone that rides in front of me complains so I usually take the lead.
Old 02-03-2009, 07:31 PM
Gwjvw's Avatar
Gwjvw
Gwjvw is offline
How are the blue lights? Are they bright? Does autozone have those?
Quick Reply: BRIGHT headlight Who????
